Fuel For Blinkers
perhapes the wires are mixed for for the turn signal and the fuel light .for a second there i thought you ment blinker fuild i was going to be like O_O might wanna change the title lol
Has anyone hacked into the wiring? That would be the first thing to look at. Also, my hazards switch is very picky. If it's not in the right spot, my blinkers don't work.
http://forums.hybridz.org/showthread.php?t=118867
I had a similar issue.
Ended up removing the switch, sanding the corrosion off, and TA-DAH!!!
[QUOTE=Philbert;254209
Ended up removing the switch, sanding the corrosion off, and TA-DAH!!![/QUOTE]
I would pop it off and check the switch too. Or just skin your knuckles and give the Z gods a blood offering. Usally works for me
ok replaced the assembly. still no. found it to be a blown fuse. go figure. i gave up lookin simple on these cars long ago. it's almost always somthin bigg. but new fuse blew out too. so. yes aftermarket radio.
same here, Mine just decided to stop working one day...looks like I should take it apart and see what the problem is.
RonK
02-11-2013 08:48 PM
