fuel injection spray pattern
Old 03-25-2010 | 09:53 AM
ITSZX's Avatar
I was having a real rich fuel situation, have done everything suggested and by the book. Still problems. It was suggested that I pull the whole injection system out and turn the motor over and look at the spray pattern of the injectors(cold start injector included). I have not seen the spray pattern before but to me it was not atomizing, more like a stream. So has anyone ever looked at this before, what does the pattern look like? no fuel out of the cold start either.
Old 03-25-2010 | 11:17 AM
The cold start has a built in relay. I think it only cranks when the temp sensor says the engine is cold and then only sprays while cranking, not when the engine fires up.
I have never looked at the injectors spraying.
Old 03-25-2010 | 07:04 PM
FubarI33t's Avatar
I am also running extremely rich, no cold start. but my temp gauge ain't workin. so i think the ecu thinks the engine is always cold. it fouls out one of the cylinders once the engine is warmed up
Old 03-26-2010 | 04:57 PM
The temp gauge runs on a seperate sensor from the ECU IIRC....
MulletMan
12-06-2012 11:14 PM
gflaurie
05-21-2007 02:21 PM
majajason240
05-11-2003 06:45 PM
ZMATTDADDY
05-12-2002 12:19 PM
jeff
08-22-2001 08:26 AM
