fuel injector voltage?
nope, actually one of my injectors are bad and need a test voltage to test them because there plugged up and dont have the money for 6 new ones so im going to unplug them, thanks for being so kind =]
did you try the injector cleaner!!!! im telling you it is the easiest way to clean them and if it doesnt work your out like 2 buks.. if you go your way your out like $8 for seals, $5 for a holder cause the will probly crack, risk messing up the injector more, and theres always the risk it will leak when you get done!!!
but if your good like me you will get the seals to seal on the first try
i replaced all of my injectors for i think $250 to $300...
cdeshane
07-23-2005 10:58 PM
