Fuel Pump Replacement
It's pretty much cut and dry. Once you get under there, you'll see that it's strapped in and just two wires go to it. Just get the wires correct and your good to go. I also put ATV on the connectors since they're directly under the "up-tube" out of the pump, just in case. Easy job, bud. If in doubt, let us know...
Welcome to ZDriver!
Here's my fuel pump replacement write up:
-Open hatch, remove carpet, remove black foam pad, disconnect fuel pump connection.
-Jack up rear of car & place on jack stands.
-Remove right rear tire.
-Scoot under car w/ a 10mm wrench, phillips screwdriver, & and a pair of vice grips.
-Clamp off the "IN" side of the hose.
-Remove 2 10mm bolts holding the fuel pump rubber mount.
-Loosen clamps on both sides of the fuel pump.
-Remove fuel pump.
-Do the oposite for install.
-Remove fuel pump.
RonK
02-11-2013 09:48 PM
Blue_streak
07-12-2012 06:03 PM
ern
10-20-2006 08:01 AM
forgottenrebel
06-17-2002 11:26 PM
