group buy on tension rods
ok im in, gimme the price in canadian no just the us price, cause i know how it works with you guys, it ends up being 5 trillion dollars according to nismo's calculator. are those the adjustible ones that were in that other thread??
Originally Posted by icice9
me too. ive seen the stock ones sheer after they replaced the stock bushings with the poly ones...
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
Im pretty busy right nowgetting ready for a track day the 23rd and my flight to MSA the 25th when im back i will set it up, as i need donor rods ( that i can pic up in the US!)
For what year car are these tention rods and are they the thing in the pic? If so let's here some prices and some benifits of these other rods please.
Attachment 4482
Attachment 4482
Yes, they are what you pointed out in the pic. With the adjusting nut, hey will allow you to adjust the caster on your front end without having to mess with shimming the stock mount point. With the ball joint, it will provide enough play to allow the rod to move freely and not bind when the suspension is compressed and you've got the steering wheel jacked in a weird way.
This is an uncommon occurance, but can happen. The biggest benefit is the on the car caster adjustment and it should give you considerably more adjustment than the factory rod would allow.
Mine are adjustable, but don't yet have the ball joint. I was originally planning on a heim joint which would give nearly the same result, but if I can get Frank to tell me what BMW that ball joint came from, I'll go that way instead...
WanganDevilZ
07-12-2010 09:22 AM
frank280zx
05-10-2006 06:46 PM
bLackout
05-10-2006 03:03 PM
