Hazard Switch rebuild
Old 07-28-2012 | 12:06 PM
WanganDevilZ's Avatar
The Emblem Thief y0!
Hallo! My computer have virus, so I no able to zdriver.com for a while, I just get brakes for vehicle, and now before I put dash in, I want hazard switch work again, can ples assist in how rebuild hazard switch, or it just need clean, cause I have 6-prong, and extra switch I have are 4/5-prong methink, so they no even compatible. I think re-solder help? When I have switch on, and bent/stretch wires a bit, lights come on fine, but when I put it at position it would be on dash, light not work.
Plese help! I no want to put dash on with switch problem!
This are only problem I have left!
Old 07-28-2012 | 12:20 PM
evandubya's Avatar
Primer Grey FTW!
I was stupid when I re-did mine and didn't take pics. I took mine apart and cleaned off all of the corrosion and put it back together. ( It didn't need solder) Oh, and there is a spring loaded part, don't loose that!!
Old 07-28-2012 | 12:23 PM
I can only imagine what it's really like in there, I won't have time to get around to it today, but I assume it's just corrosion of years, 30 is a big number for cars, I expected resistance when I bought her
Old 07-28-2012 | 01:24 PM
Do you remember if there was a little ball on top of the spring?
Yep, got it.
Old 07-28-2012 | 01:25 PM
evandubya's Avatar
Primer Grey FTW!
yes, there was.
Old 07-28-2012 | 01:48 PM
Well, no more corrosion, and my hazards come on every time now, no matter what, but I have no turn signals =(
I'll test (Later) with spare switches that I have, probably around 3am, when it goes below 90F
Old 07-28-2012 | 04:56 PM
evandubya's Avatar
Primer Grey FTW!
I'm fighting the same thing, HOT HOT HOT!!!!
Old 07-28-2012 | 08:30 PM
jaromgi's Avatar
I don't suppose you took pictures this time? I'm also having issues with hazards and turn signals. I can usually get one or the other to work.
Old 07-29-2012 | 08:39 AM
That's all there is, and corrosion can build up on the flat plates and cause an issue with connections
Old 07-29-2012 | 09:30 AM
evandubya's Avatar
Primer Grey FTW!
Are you a Sig guy?
Old 07-29-2012 | 09:46 AM
Are you a Sig guy?
Why, yes =D
http://i213.photobucket.com/albums/c...0211122154.jpg
And a S&W Guy =D
http://i213.photobucket.com/albums/c...l/DSC_0795.jpg
Old 07-29-2012 | 12:59 PM
evandubya's Avatar
Primer Grey FTW!
I like my Glock, but those are nice as well!
Old 07-29-2012 | 02:23 PM
My brother has a G19, it didn't feel very good to me. I'm not sure what it is about Glock, I just don't really like about them none too much
Old 07-30-2012 | 10:18 PM
jaromgi's Avatar
Well, I cleaned it out and now the hazards work like a charm. Unfortunately, the turn signals just won't work. Tried cleaning the connections there too, but no luck.
boosalmi
12-06-2011 06:55 PM
ZCHondaCRX91
03-23-2011 06:21 PM
280zx2by2
15
12-31-2008 09:16 PM
xtreme 2
12-20-2006 02:46 PM
CrazyLotusTT
12-17-2002 02:34 PM
Quick Reply: Hazard Switch rebuild
