Headlights
Old 11-18-2009 | 08:51 AM
FubarI33t's Avatar
Headlights
One dim headlight. one bright. No high beams. I have tryed several different headlights. and now have two new ones installed. Car bogs down when turned on. and bitchin betty shows headlight out on dash.
83 N/A
Old 11-18-2009 | 09:04 AM
skittle's Avatar
Taste My Rainbow
sounds like a charging/ wiring issue to me. It has nothing to do with the bulbs. Try cleaning all the connections and make sure everything is grounding right. Also check the fusalbe links they might be going bad.
Old 11-18-2009 | 09:08 AM
< cough .. cough >
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/dim-headlights-not-noh-moh-22117/
Old 11-18-2009 | 03:37 PM
Lesnocker's Avatar
Your in luck just took care of my lazy eyed problems. #1 Relay issue its the middle relay closest to the motor.#2 And I changed my switch, rewired the lights new relays bulbs to no aval. Turned out the fuse wasnt makeing proper contact in the fuse block.
Old 11-18-2009 | 05:29 PM
FubarI33t's Avatar
right now it could be either one. I can pop it back and forth between low and high really fast and they will start to act normal. I will try relay first, hell thats 2 secounds. then i got everything i need for switch. thanks
Old 11-19-2009 | 06:34 PM
FubarI33t's Avatar
Got it. Took switch out. sprayed down with elec cleaner(fast dry) sprayed out all connectors, and relay block. works great. Now take the old girl for a 20 hr(round trip) to the mountains!!! Smokeys here i come!
Old 05-23-2010 | 06:04 PM
terrymac's Avatar
280zx headlamp wiring diagram--colorized
I encountered a similar problem on my Z...the left
headlight went-out while driving a few weeks back.
I replaced both headlamps assuming they were same age.
While troubleshooting, I found the LOW Beam light-tab
broken-off and stuck in the socket. I removed the tab,
and reinstalled the light sockets.
The Left was dim and the right headlamp was bright.
The datsun Gru-ru said that the Light Switch had burnt
contacts. The correct New one would only cost $508.00.
SO with the help of fellow Zdriver Jeff Harthoorn who
provide me a replacement Cruise Control stalk which had
the Light-SW activator attached to it (its that plastic
piece which looks like a spoon with Dimples and Valleys
molded-in. That activator pushes against a Multi-contact
assembly. Soo I removed the assembly, 2-small screws.
Then I used a thin file to clean the contacts.
Just as you would guess the left low beam and right are
again working. I used the following S130 wiring diagram
which I colorized to troubleshoot the lights.
[IMG]c:\headLMP_Wiring2B.jpg[/IMG]
Not sure the drawing is attached correctly, as it was not
displayed.
Terrymac
Old 05-23-2010 | 06:43 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
displayed.
Terrymac
You'll have to put that picture onto photobucket/imageshack/tinypic to post it, or add it as an attachment in the post...
Old 05-23-2010 | 09:48 PM
nismo619's Avatar
Head lamp switch ..... dissconnect clean and check for burntness ... I had to find a used one from a junk yard to fix mine eazy fix.
gostlrs
10-28-2008 05:09 AM
laphamr
08-29-2008 12:29 AM
slalomskz
07-02-2008 07:35 PM
zdmcman
05-16-2003 05:08 AM
robertpark
05-12-2003 02:20 AM
