How do you know the Head Gasket is gone
Old 11-17-2008, 08:28 PM
  #26
eff good grammar
Niku-Sama's Avatar
Originally Posted by duowing
What!?
you know, dont!
Niku-Sama is offline
Old 11-23-2008, 09:32 PM
  #27
gostlrs's Avatar
Think I found the problem
i posted earlier that my zx would start but then die out at idle but keep running when giving it gas. i finally had time to look into it today and noticed a knocking noise. i reached and wiggled the belts and the crank pulley was loose, tore it apart to get to the pulley and the bolt is secure but the pulley spins freely and moves a lot.
What could be bad?
i do not have the right size socket to pull the bolt to see whats making it so loose.
anyone know what size the bolt is? i had a 1in socket and a 24mm and both were too small
gostlrs is offline
Old 11-23-2008, 09:37 PM
  #28
Merged threads so we can continue on the same original issue w/o guessing what the problem was.
NismoPick is offline
Old 11-23-2008, 09:39 PM
  #29
Should be a 27mm crank pulley bolt. If it's loose, you've probably lost the key or ground the keyway loose. To fix that means you get to pull the crank and take it to a machine shop.
Old 11-23-2008, 10:34 PM
  #30
gostlrs's Avatar
i was hoping you would not say that. i have a crank sitting around i could just swap it out. i was hoping i can just swap over the one part on the crank i have to fix it.
i might start thinking about a motor swap now if it gets to the point where i need to take out the crank
gostlrs is offline
Old 11-23-2008, 10:49 PM
  #31
Hoov for Pres!
Ratfink's Avatar
What part of Phoenix are you at?
I might have some time to stop by. But the Z is getting bad myself, and if it's too far, I will have to hold off till I get the motorcycle back on the road.
I can help you figure out what is wrong.
You can't replace the key with the crank in the block?
Depending on how chewed up it got, I know.
Ratfink is offline
Old 11-23-2008, 11:08 PM
  #32
gostlrs's Avatar
man that would be awesome, i am at 107th ave and Indian school i really would like to meet up with someone to talk about the car..
gostlrs is offline
Old 11-23-2008, 11:19 PM
  #33
Hoov for Pres!
Ratfink's Avatar
Yeah, that's out there. When I get the motorcycle on the road, I will PM you. See if you still need the help. Or maybe meet half way. My tires are showing the belt, and it scares me a little.
Coulda PM'ed me. lol
Oh well. I guess this is a pretty safe forum.
Ratfink is offline
Old 11-24-2008, 12:38 AM
  #34
gostlrs's Avatar
i have no cash to work on it now...so it will be there..LOL..i will get the right size socket i hope to pull off the pulley to see the damage and go from there.
who on here has done a V8 swap? what is a realistic price on the swap?
gostlrs is offline
Old 11-24-2008, 08:11 AM
  #35
you crazy? i lost the key in my crank for the pulley i just get a new key from napa and popped it in the crank (lost one in the timing cover in the process) and put the pulley back on. its hard but is very do-able
snwbrderphat540 is offline
Old 11-24-2008, 08:33 AM
  #36
Did you start the car w/ no key? I'm just saying... on his, if the pulley is loose & the motor has been spinning, it has likely walked the key back and forth into a nice V.
Old 11-24-2008, 10:53 AM
  #37
gostlrs's Avatar
so i will probably need a new pulley as well, good thing i have a crank sitting here to test it on to see what i need to do
gostlrs is offline
Old 11-24-2008, 11:20 AM
  #38
Hoov for Pres!
Ratfink's Avatar
I will not help do a V8 swap unless it's a Nissan V8..
No imagination. lolz
I will let you know when I can jog over. We can get everything you need figured out pretty easy if you haven't already.
Ratfink is offline
Old 11-24-2008, 10:18 PM
  #39
my pulley was missing a chunk of its metal meat right where the key was so it just flew right out! lol.
Old 11-24-2008, 11:07 PM
  #40
Hoov for Pres!
Ratfink's Avatar
The crank is a harder steel. It might survive longer than the pulley. Hopefully that is the case.
Ratfink is offline
Old 11-24-2008, 11:22 PM
  #41
gostlrs's Avatar
still working on a big enough socket to take off the bolt
gostlrs is offline
Old 11-24-2008, 11:25 PM
  #42
Hoov for Pres!
Ratfink's Avatar
Damn.. I know I have one big enough. I have wobblies that go to 1 and 1/2 inches.
But, they are in the mine I worked at, and I need a truck to get my tools. lol. I don't feel like driving back up to Bagdad either.
Ratfink is offline
Old 11-25-2008, 12:12 AM
  #43
also that bolt is on TIGHT!!!!! i had to get out my breaker bar with extension and then put the car in gear and chock the wheels lol! dont ask why i didnt just use the hand brake.....
Old 11-25-2008, 12:48 AM
  #44
Hoov for Pres!
Ratfink's Avatar
I wont... haha
I have some serious breaker bars too. And pry bars, and mallets, hammers, dead blows, you name it. Haven't had a bolt kick my *** yet.
Bolts tend to get tight over the years on these cars too. Especially steel in steel. Heat helps.
Ratfink is offline
Old 11-25-2008, 12:14 PM
  #45
gostlrs's Avatar
well i got the whole front end off so plenty of room to get in there...
i gonna see if someone at work has some bigger sockets tonight.
gostlrs is offline
Old 11-25-2008, 12:35 PM
  #46
Hoov for Pres!
Ratfink's Avatar
Checkers or Vatozone might.
Ratfink is offline
Old 11-25-2008, 02:48 PM
  #47
didnt have to take the front end off... might have more room but you coulda gotten away with not doing so and just coming at it from under neath
Old 11-26-2008, 11:58 AM
  #48
gostlrs's Avatar
i want to start to rattle can the paint to get rid of that brown crap the guy had before, so this was a good time to take it all off and do it right. on payday i will run to autozone there is one around the corner they loan tools for free. maybey they have it
gostlrs is offline
Old 11-27-2008, 10:03 PM
  #49
gostlrs's Avatar
OK..i got the bolt off....the pulley cracked and busted off. i have to get the chain cover off to see what else may have happen. so now i have a few questions..
1. to remove the oil pump it says to put the crank at the highest compression then remove the pump, do i really need to do this it i do not move the crank at all and make sure i do not move the distributor?
2. are there 1 or 2 keys on the crank to hold the pulley and gears in? it 2 and the outside one is gone..can it be replaced
3. can u just remove the oil pan and get the crank off from the bottom or do u need to remove the whole engine or just the head?
4. besides oil pump and water pump..what else should i replace while i am doing this...
gostlrs is offline
Old 11-28-2008, 12:57 AM
  #50
removing the oil pump you need the number one cylinder at top dead center for when you re-install it. basically the first piston at its top stroke with the cam not touching any rockers. the lobes pointing straight up in the air
theres only one key
you will have to remove the motor but its an easy job your mostly there already
replace the gaskets obviosly while your at it. thats it really though.
Quick Reply: How do you know the Head Gasket is gone
