I am irritated, and frustrated!
Well if that don't throw a wrench in my happiness. Carl and I have spent most of the friggin' day. Trying to get my damn motor in, it will not go in. And I am at my wits end. If anybody has any pointers, I would be happy to hear them. As for now, I think I am not worthy enough to drive a Z again. It is like I am not allowed, deserving enough, even after all the hard work I have done to this car. So anyway feel free to speak what is on your minds, and any helpful advice. I really appreciate it.
Trying to line up the motor to the bell housing. Trying to get the spline to go into the pilot bearing in the crankshaft. By the way my Z is a 5 speed. It seems like the top of the bellhousing barely goes in. But the bottom is a mile off, and it is real friggin' irritating!
OUCH.. In my opinion it takes 2 maybe 4 bolts to undo the tranny from the car.. And like 3 cables/wires....
It wieghs like 85 lbs can be picked up easily.. I would remove the tranny and connect while out of the car then slide em both in as one.. Also are you using a pilot bearing tool?? I can help Sunday if you need it LMK
Well I called my dad, and he said something about pushing the clutch in. And moving the transmission. And it should pop back into place. I haven't tried it yet. But I might tonight before I go out.
I had a fun time swaping a trany from a 83 N/A 5 speed to a 77 N/A 5 speed, had to swap flywheel's and starter's. only then would the clutch bolt up, and the trany slide into place, I know how you fell there, we faught for two day's. We finaly got it in to find out the clutch slave cylender was shot. but we got the trany in.
Okay, Put a jack under the tranny, From your post about the top being fine, but the bottom a mile off. The tranny needs to be about the same height as the rear of the motor. If the tranny is cocked down wards, in the front, then the shaft can't go in. Like when you pulled the motor, the tranny dropped down a little. So bring it back up.
I've tried all I can, and I am through with it, until somebody with more knowledge than me. Comes over, and helps me get it in. So until then the Z will not be running anytime soon. I have had enough of this friggin' headache! All the work time and money into this POS, and I feel it has been a waste. And if I continue trying anymore on it. I am going to snap, and do something I will reget.
I did it alone on a 1st gen. definitley get a jack under the tranny and level it out.
I don't know about releasing the clutch and attempting to line it up that way, because then it will be way off on the pilot bushing.
Take your time and don't get frustrated. Taking the rest of the night off will be good.
dude... did ya drop the tranny?
It is bad enought that I do a major bunch of work. And the motor is roached on 3 cylinders. But what is worse, is the fact, that after I cleaned up the other motor, and pristenely painted it like I want. The damn thing wont go back in, and it pisses me off to no end!
I definately got to go out, and release tonight. Relieve some tension, and such.
Bro, if ya got Carl's help, pull the bloody tranny! It takes 10 minutes extra time, and 3 - 4 hours of damning the car to hell.
And I am just venting, don't worry. I wont damn my Z, I am just tired of all the friggin' hang-ups.
You Can Do It Wildman, I Know You Can, Just Drop The Tranny, And Make Sure Your Starter Is Off Off The Motor, It Probably Is, Just Wanted To Mention It. Leaving The Tranny In Any Vehicle Is The Hardest Way To Put A Motor Back In. People Thinks It Will Save Them Time Yet It Takes Hours Longer To Re Insert That Motor That Came Smoothly Out. Nismo Is Right 10mins. To Drop A Tranny And Probably Less Than 45 Minutes For The Assembly To Go In. Good Luck Wildman And Carl
Thanks all you guys for the encouragement, and support. Don't worry I will be allright. Just had to get away from it for now. I will take a little break from it, and then tackle it again. With a clearer mind, and more of a fresh start.
And yes Shady my starter is out, it has been out. Because it was actually mounted to the bell housing, partly. So I had to take the bolts off it, to get the tranny free from the motor. When I pulled both motors out. So all good there man.
I know your pain. Some stuff just drives you nuts. You start tearin' up your knuckles and swearin' up a storm. Just relax, think about what your next move is and drop that tranny!! Try and find a helping hand when you do drop it though. Not necessary, but it's always useful to have a second set of eyes and hands around. Good luck.
Thanks guys for all the encouragement. Yeah SC, let me know when you can swing by. I don't go to work until 3:30pm on the weekdays. I work on my Z until 2pm or so. So I have enough time to get ready for work.
