I Failed Emissions "thoughts?"
Well I failed emissions yesterday with my Z. Damn smog *****, but I am not that upset. I am pretty sure I am running too rich, considering my fuel mileage is still low. Last tank full was 16 mpg, so I know I am still off. But not bad considering, I have been mainly guessing the whole time. I am going to my folks this afternoon, and my brother is going to help me time him. I also put some pass emissions stuff in with a full tank, after my failure. Then I will restest Thursday, and then if I fail again. My Z is going to the shop, and get diagnosed on Friday. Because the 24th this Friday is when my 30 day tags expire. And then I don't know what to do after that. Wish me luck, and here are my test results, so all of you can dissect it for me. And maybe give some more helpful hints on passing my Z.
Equipment or pressure inspection results
System ............ Result System Result ...........
Gas cap test .............. Pass Evap Componets Pass
Emission inspection results
Transient Test ............... This vehicles Applicable Result for
Pollutant ............... emissions Standard this pollutant
HydroCarbons (HC) In Grams/Mile ............ 5.35 3.00 Fail
Carbon Monoxide (CO) In Grams/Mile ....... 27.95 25.00 Fail
Oxides of Nitrogen (NOX) In Grams/Mile ....... 3.43 3.50 Pass
Euro Z King
From: Utrecht The Netherlands where owning a car is a CRIME!!
have you tried to set your AFM to run leaner ? and your timing to retard some more (note if you lean it out TO far it will harm the engine, but just for the smog testing it might help) It is really the AFR that is important. Most engines will make maximum power at an AFR of between 12.0 and 13.5, leaning it out to say 15 is dangerous under continious WOT, but would bring down the pollution in a way.
However first i would check the 02 sensor, then the AFM... you can gain allot from setting the air to fuel mixture..
I also heard reports of using seafoam before going, you might want to try that .. in the oil ( change it before going) intake, and gastank!
Luckely we in holland to have to deal with that ****
Yup, you're definitely running too rich Aaron. It looks like your Cat still works though
You should go through and make sure all the little electrical connectors are clean and corrosion free at the contacts first. That means AFM, Coolant temp sensor... all of them. Adjusting the air/fuel mixture screw is only a measure of last resort. Once you dick with it, it's a PITA to get right again. Plus, you shouldn't have to EVER adjust it. If everything else is working your A/F should be good. Also make sure your EGR is working and all your vacuum lines are routed properly and have no breaks, splits or cracks. It's pretty easy to check for EGR function and that alone can make a HUGE difference.
Rod.
Rod.
The big things that kept my n/a from passing, was timing & faulty O2 sensor. If the shop guys are cool, ask them to put it on the observation mode while you adjust the timing & AFM.
I have a buddy at an emissions shop... he can't do an "under the table" pass on my car, but he lets me use his machine to tune it down.
EGR ane Cat definitely look good to me. I dont know at what engine speed those readings are taken at but the mixture screw will only affect your mixture at idle so unless those readings were taken at idle it wont change anything. Take the advice above and change out your o2. That little thing can single handedly throw your car into an emissions failing fit. And when you go back to get your emissions test again keep the car running in the parking lot if the wait isn't too long. A warm engine is going to run a LOT cleaner than a cold one. If the o2 sensor doesn't fix your problem then I'd start looking into things like the AFM as a possiblity. ALWAYS change your o2 sensor and check/adjust your timing before an emissions inspection
Yeah unfortunately I can't afford a o2 sensor right now. But the one I have has low miles on it.
Well took my Z to my folks, and my brother helped me time him. He was like 20 degress off!(overadvanced) That is why he ran rich, and I also leaned out the fuel/air mixture, and the idle. He is running pretty good, and coming out the pipe is hardly an odor on my hands. So cross your fingers for me, I am going tomorrow back to emissions. If I fail again, I am going to the shop, and get him diagnosed. And then go back hopefully to emissions Friday. (If I have to)
o.k time for shdays quick get it through emmsions fix, i do it, cause i got a race motor in my z, unplug #5 injector. the cylinder acts like an air pump, and the car doesnt run that bad if you up the idle a little, combine that with some methal hydrate. and boom you passed. the car will only lack small amounts of power believe it or not. i even did it to a customers stock zx when he couldnt get it through. b.c. canada uses the exact to the gram emmisions program as cali, so trust me and do it, its worth your while.
Well I failed again, got close this time. Here are the readings
Hydrocarbons 4.59 limit 3.00 fail
Carbon Monoxide 20.89 limit 25.00 pass
Oxides of Nitrogen 3.36 limit 3.50 pass
So I only failed the hydrocarbons, any thoughts? Anyway I am calling a shop I took my Celica before. And set an appointment tomorrow. I am not wasting money going back and forth. Feel free to post suggestions, and such.
O2 Sensor!!! You're so close... that's got to be it. Maybe clean those spark plugs too. But don't just clean the spark plugs and go test again. The price of two tests will be what the oxygen sensor costs. Save your pennies.
16mpg is really bad though. Even after you pass with a new O2 sensor, you're probably not going to get more than 17mpg. something else is wrong there... When my FPR was bad and maxing out the fuel pressure I got about 17-19 mpg and the exhaust was noticably thick. It failed horribly... like over 100 on some of those readings.
I get about 22/23 overall with my car now.
Well I am pretty sure, I am getting better mileage now. Because he is timed correctly, and leaned out the best I can. I know the o2 sensor is old, but it doesn't have many miles on it. I am probably taking it to Pep Boys tomorrow. And get it diagnosed, I don't want to go back and forth. But man, he is running like a practically a new car. Great acceleration, shifting smooth, and sounds sweet.
And yes saving pennies, is exactly it. I am tight with money right now. I just want my Z to pass, I am sick of this **** sh#t! Anyway had to get that out. Will call them here in a bit, and see if they can look at my Z tomorrow. Thanks for the thoughts, and keep them coming.
Well the appointment is tomorrow, $84.99, for the diagnostic. Not bad, and better than the $112 I was quoted from another shop! Plus it is convenient, that the shop is down the street from my house. Less than a mile or so. So 10am tomorrow morning. Got to crash by 3:30am, and get up at 9:30am, so I can be there at 10. Wish me luck, and thanks again.
I am amazed that they make you pay for the test? In Indiana, they require only certain counties to have emissions testing on even or odd years depending on year of car, so my 300zx just passed last year, so I am good till April of 2007. I just took in my wife's 98 Chevy venture, and they dont even hook the tail pipe up to a machine! Since it had the ODBthingy, they checked to see if I had any codes on my van, and then printed me out a pass slip. All of this was free. No smog ****'s around here...
so i can do whatever i want motor wise as long as all my lights, wipers and brakes are working right
Okay a little update for you guys. I took my Z to Pep Boys down the street, and they said my #3 plug was bad. Also I have to give the one's credit on this one. My o2 sensor was bad, and I got a new one. It was $22, that was cool. The tech also said, if I don't pass, I will need a new cat. But I am sure he will pass. By the way, before you all say about the cat. I took my functional one out of my '81. Which was still original.
Now that aside, when I left the parking lot at the shop. I couldn't believe the power, and quickness my Z had! He is running like a new car, and I am stoked! If I am not careful, I could have him sideways. Man what a difference, even though I am broke because of it. No big deal, it was worth it. I am going to emissions tomorrow, wish me luck, and I will let you all know how it goes. Thanks for all the information, and tips.
Originally Posted by SHADY280
pull off #5 injector and go through aarron, it acts as an air pump. try it, its how my zed makes it through our emmisions, and they are identical to cali.
