I got my new gauges!
Pro Pumpkin Carver
So they FINALY came. 5 days too late. I wanted them before MSA but oh well. I'll do a full write up on the install but i just wanted to share for now. The illumination is the best part about them. So off the the Z I go. . . .
Pro Pumpkin Carver
I got them off a guy in socal. They are new, never installed and i got'm for 15!!! No needles but mine are already bright orange. I might change the colour though. It got too dark before i could really take everything out tonight. So i'll wait till tomorrow. I cant friggin wait.
Make sure when you go to pull the needles to be very careful not to put any pressure on the needle itself. They are extremely brittle. I broke one when I pulled my 85mph speedo to drop in a 130mph one.
Pro Pumpkin Carver
Ok so im just about done, been doing the swap over a couple nights. BUT the oil pressure gauge is what is holding me up. The end of the needle has a small block on the end that I assume is for counter balancing or weight purposes? But it is making contact with the gauge power wire because the space is so limited in the housing, so I made a few cuts int he housing but there isn't much to work with. What harm would it do if any if I removed the lower portion of the needle? Would it still read accurately?
Pro Pumpkin Carver
Another question-
I am pretty sure the gauges are going to be bright as hell so i was wondering if anyone knew how to wire them up with the stock dimming unit?
Originally Posted by apollo
Another question-
Or just splice in the existing dimmer. It's no longer going to be functional for anything but the clock since you've got your new guages. Just wire it inline with your new guages. That way you get the factory look and don't have to hassle with a new pot.
Pro Pumpkin Carver
So here they are. Sorry for the crappy pics. The whole swap turned out to be WAY more work than i anticipated, but worth it. A lot of fab work to the gauge housings is what really held me up. After about 12 hours total of work and fitting and running around for a damn petontiemeter that would work this is what i got. So i am pleased over all.
Originally Posted by 81 Black L28E
I LIKE IT LOT ......but do they make it for the 79 130mph speedo ?
