Ignition Timing *see dealer* WTH?
#27
Originally Posted by BlackzxT
there is No ajustment for 83 thats why the book says "see dealer" ..if you turn the dissy you will get some ajustment .but 83zxt's arnt supposed to run with the timing set to far off the the 24 mark
#28
yes yes i see ..hower with the ecu from 83 the reson they advanced the timing to 24 instead of 20 was to make it run cleaner with less ruff idle .
but i dont think it is as snapy . also they messed with the timing curve as every auto maker does when the
"make it better" on the the later model years ..
when you turn the dissy on the 83 how much does it change ..-3 or +3
or will it give you the whole 10 ether way ?
#29
As for setting the timing on the turbos. I originally did it like Nismo said with the TPS disconnected, but once I replaced my Ignition Module and Ignition Coil when I would set the timing with the TPS unplugged it would cause the car to run super retarded and have no power. Then I went and reset the timing with the TPS plugged in and the car runs great. I had the same problem with the Haynes in the way that it basically tells you that you can't set the car's timing without the help of a datsun dealer, but then it says you can adjust the distributor.
#30
That green / black wired plug is not used... don't worry about it. And your ecu connectors prolly have some corrosion on them. I dipped mine in some Lime-away, then rinsed them off & blew them dry w/ compressed air. Do that, and then apply some di-electric grease.
A) What exactly is Lime Green?
B) Where do I buy it?
I googled it and not much comes up. It is simular to 409?
Thanks,
wgc_3
#31
Originally Posted by wgc_3
Few questions on this one!
Thanks,
wgc_3
Thanks,
wgc_3
You can buy it in locations such as supermarkets, hardware stores, and prolly the gas station
