ignition timing
Old 12-10-2011 | 06:00 PM
Tuners dream's Avatar
ignition timing
hi i'm trying to check/set the timing on my 1980 280zx na but i cant find the notch in the pulley i tried feeling around the edges of it but at least part of it is covered by belts. I have started my car a couple times to see if it will relocate the mark to somewhere i can see but no luck. so i was wondering if you guys had any advice
Old 12-10-2011 | 06:19 PM
Socket + ratchet + rotate by hand = find notch. Then mark it with white out:
Old 12-12-2011 | 06:20 PM
Thanks that helped. I set the timing to 15 degrees, the sticker under the hood says 10 degrees so with 15 would i need to use high octane fuel? the engine is not pinging but i want to make sure.
Old 12-13-2011 | 08:34 AM
15* is fine and you don't need high octane. Just remember to turn down the timing to about 5* when you take it in for the next emissions test.
wgc_3
11-01-2006 11:25 AM
RuffZedX
04-26-2004 10:46 AM
91zxtt
15
01-10-2004 07:08 PM
Dino
03-18-2003 04:28 AM
Zmedic
07-29-2001 11:43 AM
Quick Reply: ignition timing
