Inermittent stalling at idle - exhaust leak - idle speed adjustment?
Old 12-11-2008 | 03:13 PM
  #26
Originally Posted by kiboy6
never meddled with it. Should I?
By me mentioning it twice now, I'm gunna go with a "yes". It's not likely the main problem, but it can add to the problem if not set correctly.
Old 12-11-2008 | 10:45 PM
  #27
Niku-Sama's Avatar
eff good grammar
so i am taking this corectly into thinking that:
the car tries to die when its cold when your comming to a stop and the RPM is dropping down to idle speed? but it just heeps going and dies?
and it doesent do this when its wamred up, even if its only warm slightly.
and 700rpm should be a good warm idle speed.
Old 12-11-2008 | 11:54 PM
  #28
kiboy6's Avatar
The problem is normally most noticeable right after starting the car when the weather is hot or when the engine is already hot.
The car will start right up without a problem but will then idle so low that it will sometimes cut out altogether if i don;t give it any juice. When it's idleing too low like this the idle speed seems to "bounce" up and down a little (between say 500 and 700 rpm).
On a cold day the car will fire right up and keep a good idle speed at first, but then i may notice the same problem when i stop at a traffic light a little later once the engine is warm.
Hope that makes it a little clearer
Thanks!
Old 12-13-2008 | 01:53 AM
  #29
Niku-Sama's Avatar
eff good grammar
if its doing it when its warm than its oppisite of what i had then.
when it was cold my car would dip back and fourth, some times still does it but it was a combination of things.
vaccum leaks, weak spark, not enough overall voltage, too lean and the BCCD wasnt adjusted correctly.
i fixed everything except the overall voltage. i had a hefty leak that would seal up when warm with my vavle cover gasket, mabe your getting the oppisite effect, leaks when warm. might check the bolts on it see if theyre tight, mine werent, but i replaced it any way to be safe and it was cheap.
hardenstine
07-19-2010 09:29 PM
afunnell
12-15-2009 09:37 PM
Boosted Z
15
03-20-2006 07:25 PM
JohannB
11-14-2003 03:20 PM
AceJam
07-15-2003 08:28 PM
Quick Reply: Inermittent stalling at idle - exhaust leak - idle speed adjustment?
