injector upgrade?
injector upgrade?
well its injector time and i was wondering if there was a eazy upgrade or if i should just order stock ones i dont know let me know
Without making some other changes or getting a different ECU, I think bigger injectors would run rich most all the time. You need to do some porting and install a bigger cam before you reach the limit of your stock injectors.
yeah only reason you would need biger injectors is if you pushed more air into the engine (ie. turbo or chargers or something like that...) stock will be fine.
GrayHairSleeper
05-20-2015 07:24 PM
