Just need a list one day clutch order! Napa hires idiots!!!!!!!!
Ok extremely jacked off! Just want a list of all my 81 clutch items to buy! Napa sells a flex plate but not a flywheel advanced sells a fly wheel but not the bolts. Auto zone referred met to petsmart for dachshund parts. And does anyone sell a whole god dam package? And no my 135 hp dont need a gismo super uber twelve plate flux capacitor clutch they try to sell
Me on black dragon. Any help? Thanx
Well not sure since garage space and the woman. But the clutch is beyond gone. Car just stays in engaged gears. It is also affecting starter engagement as it nails the teeth hard. So flywheel must be warped or chewed up. Just need entire assemble as regards to the flywheel napa makes it sound it multiple parts to complete a new flywheel... Don't want to drop the tranny and be stuck on stands for weeks f ing around with lil hardware items I have to find and wait for. Such as a pilot bearing not in the clutch kit that would of screwed me lol so what all I need to rebuild everything. Lol thanks
I would assume you've already verified it's not the hydraulic system... right?
Technically the flywheel is 2 pieces:
The main flywheel & the starter ring gear. I'm sure it's more trouble trying to replace the ring gear than just replacing the entire flywheel.
I suggest pulling the transmission & inspect the clutch disc / ring gear before you go buy all these parts you don't need.
Click: http://nissan4u.com/parts/280zx/us_s..._and_flywheel/
When I did this I ordered the oem style clutch kit from Black Dragon. and I ordered a new flywheel assembly from Checker Auto.
With those I had new everything. I reused the Flywheel to crank bolts because you can along with the shift fork and T/O bearing collar. which is all reusable.
Clutch Kit - http://www.blackdragonauto.com/features/z/zclk.htm
Napa sometimes lists flywheels as flexplates. I have NO clue why the hell they do that but they do. But just ask to see a pick of the flywheel. if you have an N/A its the smaller of the 2 flywheels. If you have a 2+2 Or Turbo its the larger one. Same for the clutch
Do you have time to just order a clutch kit? It will have everything except for the flywheel.
rockauto.com
or
importedcarparts.com
They were about $125 for the standard kit the last time I checked. 225mm for your 2-seater non-turbo
rockauto.com
or
280zForce
05-09-2012 06:59 AM
