King Noob
#26
The L-series is cool and all and does bolt up, but it pails in comparison in cost vs WHP. Especially now days when 280zxt donors are becoming harder to find and fewer companies are making parts for the L-series.
#27
I'll give you weight behind the rear cross member.... of course that weigh difference is 80lbs not 300lbs lol. Parts availability... hmm what can't you get for and L28? Building a stroker on an L28ET is a waste of money. MS and you don't need the MAF because the MAP is even better. Stock intake and exhaust log is good to 600HP although porting helps and cost 0$. You can bolt a Z32 with an adapter to an L series quite easily which is pretty much the strongest Nissan tranny out there. You don't need a ZXT donor - there are lots of L28ET exhaust manifolds, dished pistons are cheap and plentiful and a stock oil pan can be easily modified or just get a turbo oil pan. If for some strange reason you can't find a turbo setup F54 blocks are a dime a dozen. .....and a V6 no matter what you throw at it will ever be harmonically balanced in both modes like a straight six..... The L28ET is a simple direct bolt in.
If you were going to swap in a VG30 you're already 22HP ahead with a stock setup going with a NA VG30DE... sorry you get a troll fail with the VG30ET swap....
#28
lawlz... so the VG30 weighs slightly more than my aluminum Geo Metro 1.0L 3cyl?
A loaded L28 w/ transmission weighs 539lbs: http://forums.hybridz.org/index.php?showtopic=59086
and +2billion on everything else just stated by FricFrac.
#29
We both fail, a vg30et weighs 74 pounds less then the L28et. I have the exact numbers written, I'll post them when I get home.
Is harmonics seriously your debate in this?
#30
No... the debate is "Why the hell would anyone swap a VG30ET into an S130?!" As I stated before:
Apparently the answer is +10hp, -74lbs, thrown off weight ratio... sounds like a killer deal of a swap!
#31
I phrased that wrong. It's not really about whats available, but the amount of people making parts for them.
Agree'd, but it's not necessarily the gain in displacement that people are after while doing a build.
Then we are getting into something that can't be compared as you would be comparing stock vs. modified. And MAP sucks, if you want to really tune your car and have an accurate airflow reading, MAF is the tuners choice.
Only if you have the time, skills and tools available. I can make 600WHP on stock intake and exhaust manifolds on a sbc, but you don't see it as anywhere near efficient or anyone doing it.
After you machine the bellhousing as well. That and weren't they a group buy only? Unless someone started making them again. Even so that wuld be comparing modified to stock.
So you are suggesting to people that using N/A dished pistons are safe even though they have been known to blow ring lands? Even then just tossing a turbo and a manifold on something isn't even half the battle when doing a swap.
True. If you can't find a turbo setup what good is a new block going to get you?
Firing order has more to do with harmonics then engine configuration.
so does the VG with a simple set of motor mounts.
What the hell are you talking about? A vg30et makes 20 more at the wheel then the vg30de and weighs a GOOD amount more. You fail at trying to stick up for the l28et..
I'm just saying for how cheap and reliable vg30et's can be had now days as well as a bunch of cars that share the same motor, it is going to replace the L28et as time goes by.
