Last resort for removing broken bolt...
I have gotten the headbolt about as wide as I can right now, and I can't get a good grip on the extractor, so it just slides out (Extractors are pos imo)
Should I get a grade 8 bolt and weld it to the headbolt?
Any ideas? I've soaked the bolt in PB blaster as it was rust/grime buildup in the threads that caused this.
Input. Need Input.
0513111829.jpg?t=1305329576
Input. Need Input.
If it was my block, and same issues happened, I would drill it out to the MINOR diameter of the BOLT, so only the threads are left inside the block (if ya catch what i mean). If you damaged the threads in the block at all, i would drill up and helicoil the hole then. I helicoiled all my stud holes but thats up to you. My .02 Canadian pennies.
You can try welding... but since the block is iron, it's probably going to stick to the block too...
Last week I had a TTY (torque to yield) head bolt break on my Geo G10 motor as I was putting the head back on... last bolt snapped BEFORE it got to the 54ft/lbs. A guy on a Geo forum sells socket bolts (like the Z has) for $30 + shipping... I stopped in to my local FASTENALL shop and picked up grade 12.9'ers (you can torque the hell out of them and won't break) for $10.
Anyway, all I did was drill a hole down the middle of the bolt, wedged a square taper extractor in, and backed it out...
Hopefully you are using the square taper and not the reverse helical kind (they should be banned).
Use these:
DO NOT USE THESE:
And for kicks... my broken bolt:
Use these:
DO NOT USE THESE:
Bah, I knew there was something up with the reverse thread extractors when they didn't actually want to grab.
Where do I get a set of those other ones? No real rush, but that bolt has been in there for a while
I know you already soaked it in PB blaster but, you might also want to try a mix of diesel and marvel mystery oil, that stuff removes rust if you leave it on there for a week or so, i had a small engine with a rusty, stuck steel cylinder, so i soaked it in the mix and all it left behind was the base metal, I had to replace the piston because the rust ate away a lot on the edges, but still...
Use these:
DO NOT USE THESE:
Use these:
DO NOT USE THESE:
I have to find me a set of the square ones. Where would I find them, any sears, or are they only made by a select few??
They have various types.
http://www.arizonatools.com/screw-ex...detail/AZT174/
Unless I can find me a set locally before payday.
They're called "Straight Fluted Extractors"
the square ones are the ONLY ones that work. snap on sells them too, but at a million dollars. ive broke the square ones too tho, but they come out easier. i find it easier to weld a nut on the top sometimes before drilling, 90% of the time it works, but i find a little of the bolt has to be sticking up for that to work. and use a left hand thread drill bit when drilling broken bolts, sometimes you dont even need the extractor
