Leaky Powersteering?
So I got the driver side boot replaced on the rack and pinion power steering, and while it was on the stands (driver side was elevated) I noticed some fluid coming from passenger side boot. Once I got the boot on, I backed the car out and noticed that the fluid was power steering fluid and it was coming out of both of the power rack and pinion boots (each side)??? It did not leak at all prior to this.
Is the pump shot? Any ideas?
Thanks.
Thanks.
Any ideas on why both rack seals would go at once? I am confused on this...
A few things to know
Make sure you get a rebuilt one with the boots.
It is a lot easier if you drop the cross member!!
Keep your receipt, I had to return my because it wasn't clock correctly.
I found one online for 180 printed out the page took it to my local autoparts store and they priced matched it.
