looking for a speedo
i am trying to find a 130mph or 140mph, reasonably priced, also i found a nice set in a newer maxima that looked similar in size does anyone know the deminsions for the speedo and tach?
anybody????
that would be quite a trick to get those other Nissan gauges installed in there and calibrated.
The reason the 1979 130mph speedos are used is because they just bolt in as a complete cluster and no calibration is needed.
they pop up on eBay or even this website's classified section from time to time. Typical prices are $40-80. I'm not sure what you're looking to spend.
Haha! Your thread title says you're looking for a speedo! Did you try walmart? How snug of a banana hammock are you looking for?
Anyway, to be serious now... I may have a 130mph one becoming for sale soon.
lol yeah walmart was sold out as well....let me know when you want to let loose of yours, i am on my third cable in 2 years and its getting old.
the speedometers are calibrated the same to read according to the numbers on their face.
The plastic speedo cog at the tranny end of the cable is relative to your rear gear ratio. (or tire size change)
So you don't need to do anything but swap the speedo cluster and the banana hammock.
If you change from a 3.54 R200 to a 3.9 R200 then you would change your speedometer cable COG at that time.
I've got two actually plus one from a maxima that has the identical part number on it but the input cable is different. You can look at the speedo itself and it tells you that xxxx rpm is 60 mph. they are all made by the same company. anyway email at krs@whidbey.com and we can work out the details.
