Megasquirt
Megasquirt
SO FAR THIS IS THE CHEAPEST SITE I HAVE FOUND FOR MEGASQUIRT.. YOU'LL NEED THE SYSTEM, THE WIRING HARNESS AND THE GM TEMP GAUGE WITH PIGTAIL.
THE GRAND TOTAL BEFORE SHIPPING AND TAXES IS $358.00 NOT TO BAD.
OH AND YOU'LL NEED TO GET SOME 2 1/2 PVC PIPING TO RUN FROM THE T/B to the air filter (*where the afm sits)
it eliminates the AFM i know that much. but do you need a MAS or MAF in place of it?
Yes, you do still need a load sensor, but I believe it's set up to use a MAP (Manifold Absolute Pressure) sensor. It can be attached to any vac port on the intake.
I would strongly suggest going through WWW.DIYautotune.com There customer sevice was awesome and so are there prices. I think you might be missing a few things. I strongly suggest getting a stimulator, trust me its a big help.
Do you plan on running fuel and ignition control or just fuel?
Your sig says your car is a 79' so I am not sure how your going to trigger MSnS?
For the IAT(intake air temp) sensor you are going to want to put it on your intake manifold and close to the Throttle Body. And your also going to need the TPS off either a 300zx or 240sx, unless you already have a 240sx TB?
ooo... say any one here ever do an install ment?
hmmm... you should do a write up on the install.. everything it somew with everything you need to get adn how to install... pics maybe? that would be awsome cuase i eentually want to go standalone myself.
$280 FOR THIS SETUP
https://www.protocar.net/catalog/ind...de9e4a7ae81b50
$330 FOR THE SAME ONE FROM HERE
http://www.diyautotune.com/catalog/m...unit-p-56.html
PLUS ADD IN THE $60 WIRING HARNESS AND THE OTHER PARTS YOU MAY NEED.
This guy installed MS on his 280zxt ( http://www.cardomain.com/ride/665387/6 )
He hasn't been around in a while, but I talked w/ him quite a bit about MegaSquirt. Said he loved it. Looks like he's from "Wheaton, Illinois." Snow... is that near you?
the hybridz article is very good, i will also do the setup. one q tho, i got a 79 with msd on it already, would i then need the spark part? or can i just control fuel. ive been reading like crazy lately, but just cant quite grasp it. i even got a lappy for free for keeping in the car for tuning
Shady,
If you just wanted to run fuel control that would make things a lot easier. Honestly I dont know what you would use to control spark seeing as you have a 79'? I would ask around on HybridZ if you did want to go that way. A lot of people only run fuel control at first anyways.
