motor mounts
motor mounts
my motor mounts won't align wtf? I had to lift the engine to replace the pan gasket and now i can't seem to get the mounts to align, it looks like the motor is sittin half an inch back from where it should, im loosing my mind here someone help!
Loosen the metal arm connecting to the block... 2 14mm bolts on each. Then they will have enough movement to fall back in correctly. Set the motor mounts in place & tighten everything back up. Remember... each motor mount has an alignment tab that must fit in it's hole.
300zxtwintrbo91
09-27-2002 01:51 AM
