MSD Coil and Ballast Resistor
Old 04-07-2008 | 04:07 PM
duowing's Avatar
NisTuner
Alright since it's getting warmer out I'm thinking I'll have to go finally get my mallory ignition installed. Anyway I was wondering am I able to go ahead and throw my MSD Blaster 2 coil in there? It didn't come with a ballast resistor, and I don't know if not having one would cause problems to my stock ignition?
Old 04-07-2008 | 08:22 PM
http://www.msdignition.com/coil_blas..._8202_8223.htm
Originally Posted by MSD
There are several versions of the Blaster Coil available. All of them have the same internal specifications, but have different housings or components. Each Blaster Coil can be used with a stock ignition, Blaster Ignition, MSD 5, 6 or 7 Ignition Control. Most late model vehicles with electronic ignitions do not require a ballast resistor, check your ignition and manufacturers specifications to determine if a ballast is required in your application.
The ballast resistor is for points ignition, not electronic ignition.
Old 04-08-2008 | 09:01 AM
nismo619's Avatar
thats my question do i need the .08ohm resistor ?
Old 04-08-2008 | 09:37 AM
I just answered that question.
masterhufflpuff
04-26-2015 12:30 PM
salvi
07-10-2014 09:27 AM
NCdatsunZ
01-09-2013 05:42 AM
vrocious
09-27-2007 07:52 AM
nzz
02-20-2002 05:59 PM
