My '82 is running better!
I decided to swap out AFM's once again. I got another one on e-bay for cheap. And put it on, yesterday. Wow what a difference, I actually have gained some power back. I had to adjust the idle screw, because the ECU was trying to adjust to the new one. And as soon as it did, I had to turn the TPS counterclockwise. So here soon, maybe later today. I will change the oil to the high mileage Castrol, and see if I can get a little more power back to #3. It is wishful thinking, but it seems my oil burning has slowed down, since I have started adding the high mileage oil, when he needed to be kept to the full mark. So I am going to change it all to that type of oil. And see what happens, it is worth a shot.
I am also going to recheck my timing again, and see if it needs to be resest. Now that my Z is running correctly, I might need to change it again. It doesn't hurt to look and see. Because I think he has been running wrong ever since, I put that other AFM in him. I think it is the wrong type for my engine. Maybe it came off another Z, like an older one.
have you ever heard of Lucas? we started using Lucas oil stabilizer in our trucks that have a high consumption rate and it seems to have slowed it down significantly and it supposed to add a lot more additives to your motor oil. I don't know if your motor is consuming the oil or not but its worth a try to put a stabilizer in it i think. Its about ten bucks a bottle or so which is a low cost to preserve your motor any how see what everyone else thinks.....
Originally Posted by skittle
good luck to ya wild, good to hear you have made some progress
car runnin good eh... gonna go pic up your russian gal in the Z? do alittle first impression impressin. oh and congrats and good job.. im proud to say once i get my IC in ECU and oil T anf feed line i may have a quick surprise for all on that satus of my car... but i make no promises
Originally Posted by CraigS
Yes, woo her somehow. Your car is still in primer so paint it up for cheep like someone on HybridZ did HERE. Its easy, cheep, multiple colors give you a broad choice, and if you decide to paint it for real you can take it off without it being a health issue unlike rustolium.
Well a little update on my Z. I figured I would put it here. I changed out the oil, and put Castrol 20-50 high mileage, with a Purolator filter. Wow my oil pressure has never been that high. And I also cleaned my o2 with my wire wheel, on my drill. And boy does he have some more get up and go! I am going to be surprised when I have a Z, with a rebuilt, or reman motor. My Z is pretty quick with bad compression, in one cylinder. I couldn't imagine a n/a fresh, or a turbo. That is going to be scary.
