My '83 is Fubared!!
My '83 is Fubared!!
Well my little brother came over here, earlier today. And helped me try to run my Z. Well it definately has a thrown rod, or something broken internally. Needless to say, it is dead in the water as of now. It is a downer, to say the least. Anyway it made a horrible clacking noise, that would get worse, as you revved it. He also looked at the plugs, and told me that the motor is shot. Oh well, saves me wasting anymore time on it.
Hey! WAIT!!!! It may not be THAT bad.
Pull the valve cover off first and make sure it isn't just your typical loose valve train part floating around as has happened to many people here...
Rod.
Rod.
Originally Posted by CraigS
Take the opportunity to do something cool, V8, RB, SR swap if you've got the time I'm sure you could do it for cheep.
Too bad man, good luck.
I will have to think about what to do with my Z now. I have quite an open road, with different forks in it. I still got a good deal for the car. Just bummed, that the motor is blown in it. I might see how much a new L-28 long block will be from my dad's work. I need to give this some thought, still devastated right now.
Rod.
Rod.
Originally Posted by lww
First, do what Rod said and pull the valve cover to make sure you don't have a loose rocker arm. What in/on the spark plug made your brother think the motor was toast?
If it's only the that you need, I have an '81 block that I won't be needing soon. Well, I have the entire '81 engine, but the head has a valve lashing pad (valve #6) that keeps popping out.
Too bad you're all the way in Arizona; otherwise, I could've given it to you.
He's in AZ, but it's far enough away from you in Miami that it's close enough...
Too bad you're not closer to SanFran, WildmaN. I'd let you have the motor out of my '83 parts car. I've run it and it sounds fine.
Originally Posted by skittle
Good Luck There Wildman... Get A Turbo Parts Car And Swap Out That Byiatch.....
Originally Posted by n00blar
That sucks man, well, I had a problem with the lashing pads on the valves getting loose on my '81 engine, so I decided to rebuild my '82 spare engine.
If for whatever reason you can't find a replacement engine, and if you want to look at the '81 engine I have...here's a link to my site.
Yes, the '81 needs a good valve job and I the block was in decent shape.
I have given this quite a bit of thought. And I think I am going to put another engine in my '83. So my guitar could be put on hold. I need to think about having a dependable daily driver, that I know for sure, will not blow up on me. Yes I have a lot of faith in my Bluestreak. But his engine is tired, and I want to put him down anyway. So I can get him ready for a turbo swap in the hopefully near future.
As we speak my dad is finding out for me on a remanufactured long block L-28. I figure it will run me $600-$800 or so. With my dad's discount, at his work and such. He is a parts runner for a privately owned auto parts company. And his boss can get about anything for cars.
I am sure I could do the swap in a weekend. But I may take my time, and do it in a month. I want to paint the engine, get another set of headers for it. And clean up the engine bay, and fix up the interior for daily driver status. Anyway that is where it stands as of now. I am pretty sure I am set on this, unless by some miracle the motor in the '83 is not shot. I may check the valves, but I may need help to do that. Like what to look for, and whatnot.
My engine is just as old man. I am rebuilding the seals and such on my head very soon. I just found the valve seals(with help) at Advance. 21$ for all 12. Already got my headgasket. Now all i am waiting on is the header and header gasket.
