Need alignment advice
I FINALLY finished my suspension rebuild. Tokico Lowering Springs and struts, new tie rod ends, ball joints, tension rod bushings, upper wheel bearings. I knew I would need an alignment afterwords. I tried to drive it, but, it turns horribly. I can't even describe the feel. Any advice on what specs I should look for on the alignment? Thanks
When the steering wheel is straight, are the front tires straight? When I rebuilt my front end, I left the tie rod arms loose in the knuckle so I could drop them back out, adjust, reinstall, and get the front tires straight. Then I took it to an alignment shop and had it done professionally for $60.
So drop your tie rods and wind them out a lil until they are not pointed in.
DIY alignments....
http://www.hotrod.com/techarticles/c...ide/index.html
http://www.c-speedracing.com/howto/a.../alignment.php
DIY alignments....
