Need help with fuse ID
Old 07-10-2005 | 12:52 PM
droc217's Avatar
I have a '79 or '80 280ZX. A fuse blew, but I do not have the box cover to ID it. It is the fuse in the extreme upper left hand corner. If anyone could help me out I would very much appreciate it.
Thanks,
Dan
Old 07-10-2005 | 01:50 PM
s/cL3.0's Avatar
Bleach is my Hero
I dont know if it is different than a 82 but here are some pics that should help.. Let me know
Attached Thumbnails Need help with fuse ID-mvc-830s.jpg   Need help with fuse ID-mvc-829s.jpg   Need help with fuse ID-mvc-828s.jpg
Old 07-10-2005 | 01:52 PM
droc217's Avatar
Thanks for the help s/cL3.0, but they are the canister type fuses...
Old 07-10-2005 | 02:02 PM
s/cL3.0's Avatar
Bleach is my Hero
oh okay.. Wellit was worth a try I guess, good luck..
Old 07-10-2005 | 03:06 PM
BJ BISIG's Avatar
glass fuses
dan
i've got an 81 with the glass fuses. going by my cover, the uppermost left fuse is for the air cond (20A).
hope this helped!
bj
Old 07-10-2005 | 07:10 PM
jfairladyz's Avatar
79 is different from the 81. On the 79 diagram the upper left is labeled as HR, which is the right side headlight. Now if the wiring diagram is anything like the one for my 81, the upper left on the diagram is actually the lower left because my fuse box is rotated 90 degrees counter clockwise from the diagram, which would mean that the upper left in the car would be the rear defogger. So either your right headlight shouldn't be working or your rear defogger isn't working. Which ever is out, that's the blown fuse. All the corner fuses in your box should be 20Amps except for one, the right headlight one is 10Amps. Either way, that should make it easy enough to find your problem. If for some reason my wiring diagram is wrong, then what is the Amp rating of the fuse that blew? Otherwise, hope this helped.
emo236
02-06-2006 09:49 PM
outkast19
06-22-2004 09:55 PM
CarRamrod
01-03-2004 02:29 PM
rusty
01-02-2002 10:55 PM
