Need info on this bolt
Alright so I've got everything back in the car after a week of agony and torture. Didn't even have the injectors for half the time. Anyway I'm about done, but I can't find my one bolt. There's that one pulley that goes on the front of the head. It's connected by 2 bolts and a stud, the fuel rail also attaches around it and whatnot. Anyway the big long bolt that goes through the middle of that pulley I can't find and might need to get a new one. First off if I run the car without that bolt, is that a bad thing? Second, what size is the bolt and how long is it? Would I be able to get a new one from like Home Depot or something?
As far as injectors go. I have one 280ZX injector and 5 300ZX injectors in my car. Haven't tried it out yet. The plastic like piece on the tip of one of the 300ZX injectors broke off so I assumed I couldn't use it and put on a 280ZX injectors I knew didn't leak.
Thanks for your help guys.
Leaving that bolt out wont cause any problems with the pulley but it will allow oil being thrown off the timing chain to leak out of the engine slowly. I accidently left that bolt out awhile back and then was plagued by the oil leak for several months before i realized where it was coming from. Also, if that bolt is not tightened properly it will sometimes leak a little oil.
exavier
09-19-2002 01:56 PM
