need serious help !!
Alright you guys so this is whats happening. Car runs fine for about first 10 minutes when turned on. After those ten minutes, i rev the engine and it instantly starts to backfire and choke. RPM wont rise about 1000. Cant drive it at all. this is a list of parts i have changed.
AFM,fuel pressure regulator, chts, tps, fuel pump,ignition pick up coil,CAT,oxygen sensor, igniton module,ignition pick up coil, ECU,EGR,
Can it be the distributor?? PLease help
