need some help!..new to the forums and 280s
Old 04-09-2012 | 09:01 PM
eightytwo280's Avatar
I purchased a 82 280zx from a friend and I finally got it running..It was running very poor until i played with a sensor on the passenger side going into the block..not sure what it is..But it idled out smooth..No stumbling..So i got excited and took her down the road..I gave her gas and kicked it..It quickly accelerated to 3k and started to break up..once at 4k..ran great again..i shifted to second..and hit 3k..and stumbled and sputtered again..so i kept pumping the gas until she got past it to 4k..then it ran great again..Im at a total loss as to whats causing this issue..Ive replaced the fuel pump..cleaned the afm..and replaced the tps..Thanks for all your help!!!
Old 04-10-2012 | 12:09 AM
Sounds like maybe a dead spot on the AFM? Did you do the AFM refurbish? You could also have a bad connection on the AFM connector.
The passenger side sensor was probably the CHTS that you were messing with...
Old 04-10-2012 | 12:37 AM
Trex's Avatar
Welcome to the forum. The AFM rebuild that FricFrac is referring to is located here:
https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/js-how-rebuild-your-afm-15277/
You may also want to try getting some Deoxit or some other oxidation fighting electrical cleaner and cleaning all of the connectors around the engine especially the one that plugs in under the AFM. Good luck, keep us posted
Also: got any pics of the car??
Old 04-10-2012 | 07:19 AM
iamericgee's Avatar
thanx for this info i will be doing this on saturday
Old 04-10-2012 | 06:56 PM
Ok..So tonight i removed the coolant head temp sensor..No coolant came out..is this normal???it had calcium build up on it so i cleaned it and put it back in..Didnt make a difference...I also did the afm refurbish as suggested and also made no difference what so ever..I did notice that when I unplug the TPS sensor..No change...No idle change no performance change?...I unplugged the chts which i guess mean coolant head temp sensor..and it idles very rough..but accelerates a little smoother..but still hesitates...also i looked under my passenger seat and noticed a bunch of wires going into a box and what looks to be some relays..What is this??...sorry for so many questions..Its my first z...Thanks for all of your help!!...Chris Jones
Old 04-10-2012 | 08:28 PM
duckyz's Avatar
You seem to be on the right track... Let's start simple and go from there.
Have you done a tune up? You know... plugs, plug wires, filters, cap & rotor.
Have you pulled the spark plugs, and what do they look / smell like?
How old is the coil?
With these cars, sometimes the simple stuff is the fix.
Old 04-10-2012 | 09:00 PM
evandubya's Avatar
Primer Grey FTW!
cylinder head temp sensor, not coolant. stuff under pass seat is for cruise control.
Old 04-10-2012 | 09:10 PM
yes i have changed the plugs wires dizzy cap..rotor button..coil..i just ordered a chts
vaprobe87
01-11-2013 03:11 PM
Jasen Dean
12-06-2012 06:55 AM
blackout08
10-04-2012 04:33 PM
LeakyTopZ31
09-18-2012 08:27 PM
BobbysTL
06-07-2012 09:04 AM
