new here need help 280 has no spark
hey everybody new here helping my bud with his 280zx turbo that doesnt spark there is no spark at the coil hes changed the ignition coil and checked the injector computer and everything seems fine also check the power at coil and its at 4 volts with a multi meter the i kept power prong at power coil ring and changed the ground prong to another ground like at suspension post and then it read normal voltage so i guess its not sparking cuz of bad ground but weve checked everything and it all seems to be hooked up right could there be anything else causing this and what would happen if i ran a better ground staright to the ignition coil thanks in advance
i have also heard of some kind of igniter is that the little plug thing located on the left side seperate from the coil ?? if so as i was cranking it if u move the plug on that thing it would spark but only if that plug was being moved
Fairladyz1990AF
04-24-2014 05:15 PM
