New master cylinder...
Old 08-22-2014 | 12:52 PM
Bravenewme's Avatar
Looking for any tips/info/suggestions on replacing my master cylinder. Got the FSM, and of course it looks easy as pie....
Thanks in advance...
Old 08-22-2014 | 01:41 PM
Soak the connections with PB Blaster for several days before doing the job. And invest in a 10mm brakeline wrench.
Upon install, you will need to bleed the master, then each corner.
Old 08-22-2014 | 02:45 PM
rogerz's Avatar
Grumpy & Helpful
there is also a clutch master cylinder helps to specify which you are asking about.
Old 08-22-2014 | 05:46 PM
Bravenewme's Avatar
It is the brake master.... Any difficulties with taking the old reservoir off and putting it onto the new cylinder?
Old 08-22-2014 | 05:51 PM
rogerz's Avatar
Grumpy & Helpful
just push em on I remember. or maybe the master I bought had them attached
98blackbell
08-01-2013 01:36 AM
burble_boy
12-19-2012 05:53 PM
jurickwessels
03-27-2012 07:17 AM
dault
07-07-2007 10:11 PM
tsefreeflow
09-30-2004 01:54 PM
Quick Reply: New master cylinder...
