Newbie with some general questions
Old 05-11-2004 | 02:24 PM
EatmyDust's Avatar
I am
not an expert, but what shape are your injectors in I mean has the car ben sitting a long time.
Old 05-12-2004 | 08:58 AM
I would suggest replacing all six fuel injectors when you can. They go bad from age, even if you don't have a lot of miles on them. That is probably why the engine misses a little at idle. You can try doing the valve clearance, but it may not smooth the engine out. if you can live with the slight missfire, then that's ok too.
If your speedometer stops at 10mph, then the gauge itself is bad. Replace the gauge cluster. (used is fine) Also, there is an adjustment for the reading. After you replace the gauge, if it still reads a bit off, check your speedometer cable cog. At the point where the speedometer cable goes into the side of the transmission it connects to a small plastic gear. This gear determines how fast the speedometer reads and needs to cooinside with the gear ratio of your differential. It has nothing to do with what transmission you have as it only reads the final output shaft speed of the transmission. Your car may have had the differential swapped with another Z of a different gear ratio. If so, you'll have to do some figuring out on what ratio you have and what cog you need.
Ah yes, the 2nd gear grind. Your syncros are starting to go out and 2nd gear is always the first to go. Mine did that at 130,000 miles when I bought the car. Now, at 218,000 my transmission finally died. At about 215K 2nd gear wouldn't even stay in gear then the problem quickly spread to 3rd and 1st. What you need to do is shift smoothly and save money for a transmission rebuild, but you've probably still got a lot of life left in your transmission. By no means did I shift easy on my car. i beat that transmission into the ground from 130K - 218K
As for the little fan behind the dash, ya, mine made all kinds of noise too. I found it unplugged when I got my car. So I plugged it in and found out why it was unplugged! It sucks in air from a little round vent in the dash and reads the temperature of it. It works with your auto temperature controls in the car. those controls usually always stop working a few years after the car is brand new. Most people find manual fan controls and replace the auto climate controls with those. Just leave the little fan behind the dash unplugged.
Old 05-13-2004 | 09:55 AM
Cool
Other symptoms of bad injectors is poor fuel economy, rough idle, lack of torque, rough idle... and misfirs at idle and while accelerating.
The speedometer should always drop to zero. It is not electric. Weather the car is on or off, if you're not moving it should fall smoothly to zero. The cable spins to bring it up slowly, and not spinning the cable should let the return spring bring the needle down to zero. If it ever get stuck, then the guauge is bad.
A transmission rebuild should cost as little as $200 but maybe $300-350. You might be able to find a really good low mile transmission for $200 but you live in the middle of nowhere so that'll be hard. I would say yours if fairly low miles anyway. Sounds like they all start going bad at 100K miles. It is possible to replace the syncros yourself, but I've never done it. I'll probably try in the future.
Old 05-13-2004 | 11:05 PM
EatmyDust's Avatar
I wouldn't replace your injectors just yet man.
you discrib the miss as not a great problem, sounds like to me you should run down to the auto parts place and get a bottle of see foam they will know what your talking about, tell them it is injecter cleaner. that stuff is probably some of the best stuff on the market after using that stuff if the injectors don't work properly after a long period of time then I would check into some new injectors. Remember see foam.
Old 05-14-2004 | 10:08 AM
lifegrddude's Avatar
Externally Wastegated
Are there any exhaust leaks anywhere? It could be the cause. Or if you have larger diameter pipes it will pop a little, nothing to worry about though.
John 82ZXT
Old 05-16-2004 | 01:20 AM
EatmyDust's Avatar
I hardly think that an exoust leak or biger diameter pipes will caus the care not to fire on time, or for that matter effect the enjecters, inless that is of course you mean it is back-fireing. In that case the manafold probably got to hot blew the gasget, and warped the manefold. wich I have herd this happening often on these cars. not likely that this is the problem thogh.
Old 12-05-2004 | 12:56 AM
zeddhedd's Avatar
Do your vacuum lines too
I just replaced all vacuum lines on my 81 N/A engine and have noticed a huge improvement in the way it idles and runs. :dancing: and it was cheap too !!
Defender405
04-11-2015 11:49 AM
gergstuff
14
10-27-2014 11:51 AM
xfactor78
05-06-2009 09:09 PM
RedVonHammer
09-22-2008 04:55 AM
rob
10-23-2003 02:46 PM
