No boost
Have you specifically replaced the short vacuum lines on the wastegate actuator?
Maybe unclip the arm of the actuator from the wastegate lever. See if it moves back and forth easily. If the wastegate is the issue then it should be stuck in the open position.
You may also want to take off the large intake hose from the turbo. reach into the turbo and spin the blades to see that it is not locked up tight.
I you go from vacuum to 0 or slight positive pressure you got boost. The factory gage is notorious for being off. You can get a decent boost gage from Harbor Freight for $20 that will actually show you what is going on.
jtmny1999
04-03-2003 07:40 PM
