No brake lights
No brake lights
Ok So I have no brake lights, Oddly enough I also have no fan motor.... I do have the climate control, both worked just fine and dandy. En the fan stopped working, the motor itself for the fan does work if I jump it. About a month later I noticed the brake lights didn't work. Don't know for how long, everything else except cruise works (it hasn't for a long time) Checked all the fuses, switched fuses around, tested the brake light switch at the peddle both good. The bulbs are also good, any ideas? Also all three of the relays behind the glove box are new
Fsm
Get an FSM, use the wiring diagram to trace down the circuits you are having trouble with. What year car, always the more specific detail you provide will help in the diagnosis.
Here's a link to a downloadable Service manual, XenonS130 - S130 Reference
