No Dash lights!
No Dash lights!
It's 7.30 pm here and I just fired the Z and drove it infront of the garage. The former owner advised me that if you switch on the lights and the dash board lights to not light up, the brake lights woudn't be on either.
He said the solution is to switch off the lights, and switch them on again.
The first time the dash lights did not come on, I switch the lights off and on again and they lit up. But tonight it was a different story. I tried around 25 times switching on and off the lights. Nothing could get the dashboard lights to work. Not even the dimmer light!!
What could be the problem? Could it be a burnt fuse, loose wire?!
Which of the fuses is of the dashboard and tail lights? There are the rows of fuses located underneath the dashboard on the driver's side. I'm sure I've checked them throughly but there could have been one that slipped and still is unchecked.
i had this happen to me one night, but it was my fault resulting in no lights. i had my cigarette lighter wire loosely dangling live, and it grounded and blew the fuseable link. i checked the link the next day and replaced it and fixed my problem.
but if its not a fuseable link for you, i would check the wiring.
i know i may not be that much of help but, good luck to you.
Are there any fuses under the bonnet that I may check? If yes, where are these fuses located? Ans can anyone indicate where the dashlight fuse is underneath the dashboard?
Trying to fix the problem soon! Thanks guys!!
Re-checked all the fuses under the dash and all seem to be ok. Are he two lights that switch on when a door is open on the same fuse of the cluster lights and tail lights?
Because when I open the door the two white lights do turn on.
I inspected the fusable links and all seems to be in order, no melted wiring.
I am now remembereing that I was playing with the cluster light dimmer when the lights started to flicker and **** down.
What si the problem here? Really bumbed as I cannot take the car out at night!
The dimmer switch will sometimes cause these issues. Do you have a digital or analog dash? Please update your profile to include the year of your car, so we don't have to hunt for it.
Hey barbie, it's an analog dash. it's a 1979 Japanese Spec 280zx. Any help on how to check/ fix the dimmer switch would be greatly appreciated!
I'm sorry if I haven't explained the situation that well. The brake lights to light up normally. However it is when I switch on the hedlamps that the back lights to not switch on.
However the brake lights still switch on when I press the brakes in the dark with the hedlamps on.
Still haven't as I don't know what to check!
It seems to be coming from the dimmer switch because back when the dashboard lights used to switch on, when the dimmer switch was turned, it used to 'flicker' the gauge lights and it was after touching the dimmer switch that the lights did not come back on.
Shall I pull out the dimmer switch and check for loose wiring/shortage?!
A few questions might fix the problem.
1. If the dimmer switch is faulty (bad earth etc..), would the tail lights, license plate lights and front lights fail to operate as well?
2. Are there any fuses to check under the bonnet? If yes, please tell me where they are at. And which of these fuses is of the tail lights, dashboard light etc. Remember mine is a RHD and the interior fuse box is located on the driver's saide (right on the car)
Yes, seems strange. My memory is a little fuzzy, it's been awhile but I do recall in my case the tail lights, either a bulb or fuse being related to intrument panel going dark. Doesn't hurt to check bulb and recheck fuses. Maybe a bad fuse that looked good and now has completly failed. Do the easy things first.
I guess I found the problem. Was checking the fuses carefully and I noted that some are rated 25amps and even 30 amps which the haynes manual and this fuse box cover off a 1979-1981 280zx does not show any fuses above 20amps. Half of the fuses I have in are the old 'wir'e type fuses that can be blown but hardly seen.
I'm possitively sure that the fuse box cover show here is off a left hand drive car as i got the picture off ebay.com. Would the diagram be the same for my car?
My fuse box without cover!
No dash, tail or license plate lights
Ok I moved this thread here because I wasn't getting that much posts on the technical forum.
So when I bought the car, the guy told me if the dash lights go out, assume you won't have tail lights neither. He continued to say that the solution for it is to switch off the light switch on the turning signal switch and re-switch it on. This worked wonders for a few times the dash light failed to operate.
This is what should be lit with the first turn of the light switch. Now with the first turn of the light switch, none of these light up.
I then went to install A headunit in the dashboard as the former one was blown out. I recall that the dash lights, tail lights and license plate lights did turn on after the new stereo installation.
If I recall well, it was when I touched the dimmer switch that these lights didn't seem to operate as I switched on the car a few hours after touching the dim switch.
I hear a click sound coming from the top box shown in the pic.
Fuses are ok
Fusible links seem all connected
Have no idea how to get out and check the dim meter. Can it be a connection on the light switch?
Fuses are ok
I have combined your new thread to the old thread because they are on the exact same topic, and we don't need to go over the same things again.
Finally i've solved the problem!!! It's was the combination switch. Kust cleaned the contacts and now is working in order. To thank everyone who help me in any way, please refer to my other thread with some day-time pictures of my Z!
