No Point, just an obsevation
Old 08-07-2006 | 01:11 PM
thxone's Avatar
I was looking at several pics of S130's and I noticed something. In every front shot that I looked at the mirrors seem to not be on the same plane with each other. I thought my eyes were playing tricks on me but they were not. The passenger side mirror seems to be at a slightly different angle. I tried to tell my buddy (JBs280z) this and he thought I was messed up....then we took some closer looks at our cars. We noticed that the drivers side mirror housing is one molded piece and the passenger side is two pieces. Why would they do that...dunno.
We got out the measuring tapes to look for where the differences were using the drivers side mirror as the control. We found that the passenger mirror housing is turnend towards the door slightly on the horizontal plane and tilted away towards the ground slightly on the vertical plane. I have no idea why they would be build it this way....maybe the original design called for one mirror? We did come away with the same measurments on our cars, his being a 1980 2+2 and mine being a 1982 coupe. Anyone know why they would make the mirrors different, from the housing to the mounting angles?
Old 08-07-2006 | 01:48 PM
FubarI33t's Avatar
I have not noticed that. small detail. But i did find somthign out about my Z today. Door Lock Timer. these things lock them selfes up?
Old 08-07-2006 | 02:24 PM
Heat Rave R's Avatar
That door lock timer must be part of your alarm system. There isn't even a factory power lock in the driver's door. As for the mirror, I assume the passenger side housing has a much different angle because of how the mirror must be angled much differently for the driver to see it properly. I guess if the housing were positioned the same as the driver's side, the mirror wouldn't be able to angle itself inside the housing as much.
Old 08-07-2006 | 02:53 PM
FubarI33t's Avatar
the door lock timer box is located right behind the ECU. and is factory.
Old 08-07-2006 | 02:58 PM
duowing's Avatar
NisTuner
that's weird, my car doesn't do this auto lock thing.
Old 08-07-2006 | 03:00 PM
thxone's Avatar
Nor does mine...would be nice though, I do forget to lock the doors sometimes.
Old 08-07-2006 | 03:14 PM
My '82 did have the power locks, until the rod in the driver's side door came off. And I haven't felt like taking the door apart to fix it. If I unlocked the dirver side, the passenger side would unlock too. Also if I locked the driver side, the passenger side would also. As for the mirrors, I wondered why the passenger side was more angled. I figured it out on my own, after seeing bunches of S130's, and I concluded, it was for the driver's vision.
Old 08-07-2006 | 03:28 PM
FubarI33t's Avatar
I can't lock my driver door. It jamms when trying to unlock it. plus my key don't work for locks, so i can't lock it anyway.
Old 08-07-2006 | 03:55 PM
RodMoyes's Avatar
Doesn't post much...
Huh... I learned something about my car in the last couple of day's too.
I'm starting to hate it.
Rod.
Old 08-07-2006 | 04:16 PM
Carl's Z's Avatar
My mirrors do the same thing. I thought it was tweaked or something...
Old 08-07-2006 | 10:19 PM
jsutter85's Avatar
my 81 didnt even come with a passenger side mirror.
Old 08-07-2006 | 10:30 PM
There are 2 diff versions of the 280zx...
The 79-81 & the 82-83
The 79-81 had a base model option that included (better said "excluded" these items) manual windows, no power steering, basic stereo, etc...
The 79-81 GL had all the basics...
The 82-83 was aimed at sport luxury & all came with: bumper/fender/door moldings, t-tops, voice warning box, power locks, turbo style NACA hood scoop, etc.
Old 08-07-2006 | 11:11 PM
SpeciallySpiked's Avatar
I'm a Registered User!
mine still don't lock on their own...
Old 08-07-2006 | 11:23 PM
It's not the "auto locks" like today.
The 280zx auto lock is thus... Lock the drivers side, and the passenger side locks too. Unlocking is the same. If that isn't working, check the fuse & electronic lock box.
Old 08-07-2006 | 11:36 PM
Not factory right
Old 08-08-2006 | 06:45 AM
Warren's Avatar
Actually, the "Door Lock Timer" is merely a power relay for the door lock servos that has a couple of functions, NONE of which have anything to do with "timing" or "auto locking". Below are diagrams of the basic circuit and the circuit schematic taken from the 82 ZXT FSM along with the troubleshooting procedures.
These cars did NOT come with an AUTO locking feature, other than the description listed in the illustrations above. Any dreams and aspirations of auto locking would have to be coming from some aftermarket device (aka alarm system) installed on the car.
Old 08-08-2006 | 08:34 AM
FubarI33t's Avatar
not unless you get creative and wire the light fader into the lock system. Then when the lights finish going out. the locks would lock. but just an idea.
Old 08-08-2006 | 09:10 AM
PooFlinginMonke's Avatar
Open the hatch and take a picture of the front seat orientation if you want to get alarmed.
You will see the seats both angle in toward the center of the car instead of being straight.
Has to do with the fact that they only latch on one side and the seats bend in time..........sometimes faster if you are heavy.
Old 08-08-2006 | 12:59 PM
Warren's Avatar
That's not correct.
Actually, if you'll look under the seat, you might have to remove it to see it, there is supposed to be a wire that connects from one rail latch to the other (so that's what thats for ). So they DO, in "fact", latch on both sides, unless somebody screwed them up. The bending comes from the fact that the seat frames are CHEAP, plain and simple. You can bend them back in shape all you want to and they'll still distort...heavy or not.
Old 08-08-2006 | 11:07 PM
drlew's Avatar
a few years back I let my wife drive my car ONCE. thats all it took. somehow, she snapped my key in the driver door. I still haven't gotten it out. I have to lock my driver door from the inside (passenger seat). then get out and lock the passenger door.
reverse steps above to get into vehicle...
Old 08-09-2006 | 07:43 AM
lww's Avatar
lww
Head Muckraker
Ok, that would drive me freakin' nuts. I would have already had the lock out and to a locksmith if I couldn't get the key out myself.
Old 08-09-2006 | 09:00 AM
FubarI33t's Avatar
i got to get a new set made for my locks. or just new locks with key's for both doors and hatch.
Old 08-09-2006 | 09:57 AM
lww's Avatar
lww
Head Muckraker
If you get new door locks, you can take your other locks off the car, take them into a locksmith and they can set them all to the new keys.
Don't forget your glove box lock! Don't ask me why I remember that one so well...
Old 08-11-2006 | 11:08 AM
Originally Posted by Warren
That's not correct.
I was meaning the latch on the tilt not the seat rails.
This is why you find a pawl/lock mechanism on one side and a mere bolt on the other.
Old 08-11-2006 | 03:54 PM
Warren's Avatar
[QUOTE=PooFlinginMonke]I was meaning the latch on the tilt not the seat rails.QUOTE]
OOPS My bad, sorry about that...I had forgotten about that latching mechanism, but the seat frames are still CHEAP!
cbaumy34
08-29-2013 07:50 PM
DarrellBuddy321
12-10-2004 12:01 PM
MetalTear17
08-22-2004 10:26 AM
cerealkilla
11-08-2003 07:27 PM
auxilary
10-03-2003 10:25 AM
