No turn signal
Old 06-26-2009 | 12:24 AM
gdcat51's Avatar
No turn signal
I just purchased a 81 280zx. The turn signal signal and hazard lights do not work. All other lights work. I have replaced flasher and checked all fuses and bulbs. Any thoughts?
Old 06-26-2009 | 06:52 AM
Welcome to ZDriver!
It may be the hazards switch located on the left side of the column cover. If that switch is not COMPLETELY on or off, the turn signals won't work.
In your case neither work? Check / replace the hazards switch.
Old 06-26-2009 | 10:46 PM
gdcat51's Avatar
Thank you for your suggestion. Neither the hazards or the turn signals work. Do you know if there are flashers for both the hazards and the turn signals? I can only find 1 flasher. Thanks...
Old 06-27-2009 | 12:15 AM
BlueKitsune's Avatar
Intrawebz Wizard
You need more blinker fluid, Its hard to find more but some auto store do sell the stuff.
Im not making this up either you CAN buy "blinker fluid" Its in a bottle like brake fluid but its filled with distilled water for your battery lol
ANYWAYS for the real part now, I think you have 2 flashers, one for your hazards and one for normal use, You could either have one blown out, a short in your line somewhere, or you have a bad ground, Id start checking the wire and the switches, and doesnt hurt to replace the flasher unit.
tennis280zx
04-01-2013 02:34 PM
ZachZ-
12-28-2012 12:37 AM
jiyu-z-chick
06-29-2006 10:16 PM
rookieszx
07-15-2004 02:41 PM
OrangeZ32
06-19-2004 03:35 PM
Quick Reply: No turn signal
