noob question msd blaster ss
Old 07-04-2012 | 04:08 PM
henrycas's Avatar
do I need 0.8ohm ballast resistor with this coil (msd blaster ss) or just simple conect the blue wire to (-) an the Black/White to (+);
I see most of you are using (msd blaster coil 2) and not the Blaster ss why?
Old 07-04-2012 | 04:32 PM
I use the Blaster SS... you don't need a balast resistor because you're not using 6V points...
Old 07-04-2012 | 04:43 PM
henrycas's Avatar
ok thanks! every day i learn something with you guys.
Old 07-11-2013 | 01:29 PM
ZUL8R's Avatar
I know this is a very old thread but I have a 240 that was installed with a crane cams xr700 optical ignition. I removed it and installed a ZX distributor. I would like to install an MSD Blaster 2 coil with no ballast and open my spark gap a little. would this hurt the ZX ignition or mess with my Tach?
Old 07-11-2013 | 07:27 PM
zedsdeadbaby's Avatar
shouldn't
ch33z3x
03-17-2014 01:42 PM
ttxz003
11-08-2012 04:10 PM
kyle_wise07
07-22-2011 05:05 PM
BartKnox
04-06-2003 03:42 PM
pHiL53
03-22-2002 10:20 PM
