Not happy with my ZX
Old 04-05-2007 | 11:26 AM
  #51
Sweets's Avatar
Usedta be Justin260z
Mine just come out straight up. Then again, I have the cleanest engine bay on this forum
Old 04-05-2007 | 11:32 AM
  #52
Really? Lets see pics.
Old 04-05-2007 | 11:35 AM
  #53
Sweets's Avatar
Well maybe tomorrow. It is pretty clean though, im not gonna lie. Im sure someone else here has a nicer engine bay than mine.
Old 04-05-2007 | 11:43 AM
  #54
thxone's Avatar
No...it still wont come up and out...fuel lines, power steering pump, Alternator pulley. Holy crap, I am gonna yell pretty soon...to think I have yet to do this on my '82 so I can swap them
Old 04-05-2007 | 11:50 AM
  #55
Post a pic of the working area.
Old 04-05-2007 | 12:00 PM
  #56
Carl's Z's Avatar
Goes out the bottom, behind the rack and in front of the wheel well. Coolant hose off is only way. Just gotta manipulate it some, but it will go...
Old 04-05-2007 | 12:55 PM
  #57
thxone's Avatar
Success!!!! I got that bastard out!!! Undo the fuel lines, move out of the way...Unbolt powers Steering, move out of the way, Undo Coolant hose, move out of the way and she comes right out with a whole lot of room to work. Had I done this to begin with it might take 20 min start to finish with new Alt in. Now....off to remove the other one and put all this back together!!!
Thanks guys.
Old 04-05-2007 | 02:05 PM
  #58
all I ever did was remove the power steering pump from the bracket on the side of the head and pull the alt up and out.
great jorb
Old 04-05-2007 | 03:03 PM
  #59
thxone's Avatar
She is running with no leaks and charging above 14 volts at idle....be back with video....
Old 04-05-2007 | 03:50 PM
  #60
thxone's Avatar
Well here is how she sounds, though I could not get on it...damn Florida elderly drivers!
Old 04-05-2007 | 05:36 PM
  #61
thxone's Avatar
Well, tested the old alternator and it was charging at almost 17 volts....uhhh thatsa no good. They said it could have caused a fire. Damnit...I was hoping to spay my car with the hose
Shady was 100% correct....whats new. Thanks for the help shady.
Old 04-05-2007 | 08:39 PM
  #62
hey guys the fastest easiest proven way to get the alternator out, is to remove the 3 bolts that hold the bracket for the alternator on. it takes 5 minutes. you just need to rotate the alternator around a bit, and your done!! too bad im not on here during the day to help good to hear thxone!! ive done lots of alternators, trust me, 5 on my car alone!
Old 04-05-2007 | 09:27 PM
  #63
lww's Avatar
lww
Head Muckraker
Yeah, what Shady said. I've never had to remove anything when replacing the alternator. I used to replace them every 6 months or so on my 1980 280ZX when it had a 2300 watt RMS stereo system. I would burn through the diodes in about 6 months. Fortunately, my neighbor's father owned an alternator/starter repair shop. I bought an extra one and he would rebuild it right away and just keep it on the shelf for me until I killed another one, I would drive to the shop, pull the dead alternator in about 10 minutes, put the new one on and by the time it was all buttoned back up, he would have the bad one rebuilt!
You just have to pull it towards the back of the engine bay and twist it out at the right angle and it should come right through. It should go out the bottom pretty easy too.
Old 04-06-2007 | 02:07 PM
  #64
thxone's Avatar
Well, I think I still have all my factory stuff on the car...like the pan below the radiator and other stuff that was in the way. I don't mind doing it the way I had to...now that it will take no time at all to do....which I am sure I will now that I have my 1,000 watt beast!! (see audio thread)
Old 04-06-2007 | 02:18 PM
  #65
Hey man, don't feel bad. It took me over 8-9 hours to do an alternator change. And I had to, so I could go to work that night. So I only got 2-3 hours sleep that day. Man I was a mess that night, but I survived. Now I can change an alternator in about a half hour or so. A cake walk now, glad to hear it was a success for you bro'
Old 04-06-2007 | 03:21 PM
  #66
duowing's Avatar
NisTuner
Don't you love how the first time you set out to do something simple it ends up taking hours.
Like doing the injectors on the Z. First time took me like hours to just get that crap out of the car. Now I can pull the injectors and put them back in in about an hour and a half or so. Probably faster.
Old 04-06-2007 | 03:25 PM
  #67
I've done so many alternators that now I can actually do it blindfolded & my hands tied behind my back. Bleach still has to use his Nintendo powerglove.
Old 04-06-2007 | 06:26 PM
  #68
bilherd's Avatar
That hose that was pulled off may go to the bottom of the throttlebody, hard to spot unless you look directly at the TB.
Old 04-06-2007 | 06:49 PM
  #69
thxone's Avatar
I will look for a vacuum line connection on the TB....I know I still have leaks somewhere
Old 04-06-2007 | 10:15 PM
  #70
there's nothing wrong with using the Powerglove to work on a car
Old 04-07-2007 | 01:45 PM
  #71
duowing's Avatar
NisTuner
At least it's useful for something.
Old 04-09-2007 | 10:07 PM
  #72
duckyz's Avatar
HA!!! The image of that....
NismoPick
12-24-2011 10:54 PM
PBking51
07-09-2009 07:26 PM
FubarI33t
05-19-2006 06:07 PM
RPS13_GZ32
02-10-2006 03:47 PM
GodZilla
08-27-2002 10:52 AM
Quick Reply: Not happy with my ZX
