Overheating damage?
Overheating damage?
a friend drove my car earlier today and it overheated while they had it when they got back i could not get the thing to start. can i get a list of possible "small/easy" things to check before investing any serious cash??thanks in advance
thats why you dont lend cars. you better make them pay for it. cause if you cant get it running after overheating, its usually not a fun reason why. when a car overheats everyone knows to turn it off. your friends are idiots. also if it got to hot could have started predet or just baked the engine and oil and maybe even internal crap like piston rings. but i like skittles idea better. go an compression test the cylinders.
Ok, when you say it wouldn't start...would it crank and just not start, would it not crank at all (no noise) like you turn the key and nothing happens? Sometimes a starter will get heat soaked and make it a real pain to start a car, our cars are prone to vapor lock in the fuel line...one reason why we have the blower for the injectors and fuel line area, when a car is over heated the engine will continue to expand when turned off and get hotter before it cools back down due to lack of coolant flow, sometimes it is just fried in which case you need to beat the hell out of your friend or sleep with his chick...or something to show how mad you are. Can we get some more info as to what the car was or was not doing when you tried to start it?
let it sit for a day, then try, also if the motor gets real hot it can kinda seize up, not really bad, but its not good, it is very possible that if your head gasket is weak, it woulda blown. do a compression check, and a leak down check. (youll see bubbles in the coolant, or hear a leak across cylinders)
update
well went to do a compression test but the noticed the "t joint" running off my heater core was leaking. i am going to get a new one in a few minutes, but funny thing was the car started??? had a lil bit of smoke but then idled out and ran fine for bout ten minutes...going to my parts car in few though so will give an update later
![Unhappy](https://www.zdriver.com/forums/images/icons/icon9.gif)
fuel, it got to dark to mess with tonight so back to it tomorrow....will start with new plugs, and go from there. like i said it ran good sat when i got it started and noticed antifreeze leaking out so i tuirned it off, not wanting to do more harm now it won't start
when my car over heated my thermo froze. I lost All my coolant from the head gasket down the side of the block. you could see is gushing out. I let it sit for 20 mins. added water. and tried to crank. Batt was dead. But i let her roll down hill and dropped the clutch. she started right up. and drove home. head gasket sealed right back up. and i drove her for 1600 more miles before i put the new head on. she never leaked again before the new head.
for today: goit a new CHTS, distributor, AFM, going to install in a few plus as an added bonus found a new parts car and got the taillight that was busted, talking lady box and some chrome trim for the entire car. found a 82 zxt that the front end was caved in but other then that body is excellent wish me luck, oh one more thing just recentlly removed my tint that was becomming hazy any recommends on what type of tint to replace it with?
![Big Grin](https://www.zdriver.com/forums/images/smilies/biggrin.gif)
i need to remove my tint. I have not figured out the best way to do that.
DO NOT DO IT YOURSELF. Get it installed by a pro... unless you want the haze & bubbles to come right back. ![Big Grin](https://www.zdriver.com/forums/images/smilies/biggrin.gif)
Glass cleaner & a razor blade. As for the hatch window... well it's just a biotch to get the tint off of the defroster lines. If you can grab a corner & pull the whole sheet, that works best.
As for applying the tint, I agree. Let the pros do it. It's very involved to do it and get it right with no bubbles.
![Talking](https://www.zdriver.com/forums/images/icons/icon10.gif)
jumping for joy right now!!!!! replaced the CHTS hooked up jumper cables and poof she is back in my garage now and getting ready for some serious going over, thx everyone for the help since that is my baby getting her ready for paint and will post pics as sone as she comes back (was supposed to be gone yesterday!!!) also the three z's i have have almost all parts on them, 79 280z, 81 280zx, 83 280zxt
