Paint removing
Old 09-14-2009, 11:00 AM
  #26
Intrawebz Wizard
BlueKitsune's Avatar
Nice, Man the headlight buckets are some thick fiberglass then. And I guess I'll use etching primer on the painted body of the car, and I'm just going to undercoat with POR-15, I do the entire car if it wasn't $130 a gallon @.@
BlueKitsune is offline
Old 09-19-2009, 09:15 PM
  #27
Jasondiz's Avatar
I've begun removing the paint off of my 3rd datsun and its has about 6-7 coats of paint on it. Its going to take time no matter what, so be patient. I've been using Jasco Premium paint & epoxy remover that i picked up from Home Depot for 25 dollars. I chose this because auto stores were wanting about 36-40 dollars for a gallon of aircraft stripper. Its a thick brush on semipaste that i especially like b/c of the low odor to it and b/c it is so easy to apply. It only takes about 10 minutes before you can take a scrapper to it but the downside to it is that it takes about 3-4 coats to get down to bare metal for me and then finish it out with 400grit sand paper on the DA. Also this stuff melts away bondo with is also a plus.
Jasondiz is offline
Old 09-19-2009, 09:22 PM
  #28
Intrawebz Wizard
I honestly forgot about this thread.... I guess now would be a good time to do the engine bay which is starting to rust sense theres no paint around the brake and clutch master cylinders
Maybe I should just pull the engine.... hmmmmmmmmmmmmmmmm
Old 09-20-2009, 08:52 AM
  #29
Jasondiz's Avatar
Thats always a good start, I regret not painting the engine bay when i did a engine swap b/c now i have such a new shiny paint job but when you open the engine its like oh damn, the original paint covered it black oil marks but luckily no rust
Jasondiz is offline
Crusty_Lips
08-21-2013 10:32 PM
Turbo Biscuit
03-29-2012 07:37 AM
Switchtr3
02-21-2010 09:56 AM
skittle
11-17-2006 06:12 PM
merjii
07-05-2006 07:27 PM
Quick Reply: Paint removing
