Pedal assembly cracked . . .
Anyone ever had a problem with where their clutch bolts into the pedal assembly? I was driving around today, and when I depressed the clutch I heard a fairly loud crack from the pedal box - no more clutch. Took a look under there, and the fulcrum where the pedal meets the metal has cracked so it can no longer push the clutch clevis far enough to disengage the clutch. I stopped by a local repair shop that I saw on the way home, and he took a look at it . . . "huh, kind of a bad design - really thin metal that the clutch is levering against". I tried to convince him to rig me up a push-rod with a handle that I could use with my left hand, but he wouldn't do it.
Did quite a bit of searching, but didn't find anyone mention this happening to them before . . . was this just a fluke thing, or should I be worried about it happening on a replacement pedal assembly as well?
I'm working tomorrow on pulling out the assembly, already have the steering wheel off and the dash mostly apart so it hopefully won't take very long. I'll take pictures of actually what happened once it's out.
And while it's laid up, I do have some new brake lines and a thermostat I should install . . .
Awesome - I may take you up on that. Heading out now to brave the cold & get it out of there, I'm not looking forward to it . . . 14 degrees out there.
Man, pulling this thing out was a real bitch. I can't think of anything other part on the car that requires this many parts to be removed!
Wish I had a better camera than just my phone, but you get the idea. Top & outside brackets are completely separated, the small inside bracket is almost torn through, and the inside pivot is halfway torn off.
Any opinions on if it's fixable? I'm bringing it to a local guy later today so he can see it.
If it were just the one big spot, I'd have it done no question. But the top bracket needs to be tacked as well as the little inside bracket is tearing. But toughest is the inside pivot point (hardest to see, but there's daylight in the 2nd picture that shouldn't be there). I'm not sure repairing that point is possible without seizing the whole assembly.
Or rather, I don't know a welder with enough skill to do it.
Found a cheap pedal assembly, so it shipped today. Car will be out of commission until next week.
Stopped by a local(ish) yard with some 280zx parts to see if they had a pedal assembly & a few other odds & ends I'm looking for. No luck on anything I actually went for, but I did find this little diamond in the rough:
P90a solid lifter head. $60.
There's a P90 and a P90a. the A was hydraulic lifters and the P90 was solid, though otherwise identical heads. Unless I'm missing info, that I just didn't know about? But yes I saw that... Honestly, I don't find there anything special about those heads. From what I have read from people flow charts on all the heads, stock, they all just about flow the same. Plus they don't make SS valves for that head and you have to use the ones built for the earlier head styles if you want them (which is almost needed for upgraded springs and higher revving motors) which is minor modification, I forget exactly, not a big deal, but in the end, I think I'd take an N42 head over it... If I were going to build a head that is.
From everything that I've read, it takes the least amount of work to make it ideal for a hot street engine. Combustion chamber doesn't need extensive welding, and it works well with the inexpensive OE flat-top pistons for good knock resistance while keeping higher compression to help out a bigger cam. This will be my long term n/a project head.
p-series heads outflow all other stock heads. there is a flow chart around the inter webs somewhere i think it was on hybridz. great find tho, no liners, good for turbo or insane porting on na applications
Oh yeah, I forgot to update this, didn't I.
I got the "new" pedal assembly - broken one is on the right, believe it or not:
Not sure why mine was painted & the junkyard replacement I got obviously never was. But some work with a wire wheel & some Krylon & it cleaned up nice:
Got it all installed a few days ago, everything working great except for my horn. Not sure what's up with that yet.
Someone has tampered with it then, because the orig wasn't painted from the factory. That could explain the crack... maybe someone messed it up accidentally, or tried to fix it, and botched it...
Its hard to tell from the pic, but it looks like metal fatigue. If it has any kind of movement in this case clutch in and out. it gets weaker until it gives out and cracks, then the added stress pops the tack welds.
