Places to get bigger fuel injectors?
So as I prepare to finish up my '88 Z31T ECU conversion on my '82 ZXT, I find that I would need to splice in resistors to make the original fuel injectors run at the right impedance. I figure the better long-term solution would be to just get the correct high impedance injectors, in a larger size to meet my horsepower goals.
So what I'm looking is an affordable and reputable place to get injectors from that are:
1. high impedance
2. hose feed type (instead of o-ring)
3. +/- 370cc
So far, the only place I can think of is RC Engineering, which runs about $88/each. I'm just wondering if there are any other reputable injectors for a better price.
Also, would the bigger injectors cause me to fail smog due to more fuel at all rpms, or would the Z31T's ECU compensate?
1. high impedance
3. +/- 370cc
In my experience, Nissan ecu's can only compensate for a 10% +/- size in fuel injectors and be ok. Other than that you will be running way too rich. Whatever you do, avoid Venom injectors. Ask the Supra guys why they run from them like the plague.
Originally Posted by lww
OlderThanMe
10-04-2005 02:39 PM
280zinkansas
04-27-2004 10:26 AM
