plug underneth the intake manifold
ball bearing or something inside it that moves up and down. Located next to turbo sleeve, you know, has 2 hose clamps hooked together.
I pluged it, does this have any thing to do with wastegate atuater or turbo funtion?
kenny and jimmy
kenny and jimmy
*facepalm*
by the sounds of it Its the PCV (Positive Crankcase Ventilation) Valve. It should be hook into that pipe the come out from the block on the drivers side under the dizzy. And you need it hooked up else you want something to blow up.
How would not having the PCV hooked up blow something up?
Hmmmmmmmmmm??
Anyways Yes Im talking about the pipe off the engine block... what other pipe is there? and you can but its a very bad idea. Where does it go? Uh lets see it goes from the pipe to the PCV valve with a rubber hose.
Your welcome lol
Yes it's the pipe off the engine block under the manifolds near the front cover.
Some people block it off and put a filter on the valve cover opening. Sometimes this can lead to oil coming out of that filter but usually it's not that big of a deal, although frowned upon.
thanx
Lol you are in serious need of a Haynes manual or FSM
Thanks for clearing that up for me....
this engine was tore down in 06...I can't remember where everything goes.
I do have a fsm for the car, just can't make heads or tails on the drawings, I honestly could not find that valve. I blew thru it, mine opened both ways, thought I'd loose turbo boost. In this case, id go back into the engine...?? maybe the valve is bad, anyway I blocked it off and will put a filter on the pipe coming outta the block.
I should have her running today and will report back progresss
thankx to all at zcar, without you guys Id be fed.
kenny
zdriver
sorry bout that, zdriver guys are more friendly than on the other forums, thats why I hardly ever post there.
I do apreciate everyones help, when you have a quesstion and post it here it gets answered.
I met Fubar here, and everything he worked on for me was spot on..and we became friends.
Hope he stays safe in Iraq.
kenny, jim left the building for good.
noelawinslow
05-21-2013 01:17 AM
