Power locks and windows
Just curious but does any one know WTH they put power windows but not power locks on an 82 zx.
On that same note, has anyone here moved their window switched fromt the door to the console. I keep hitting mine with my knee and it will sort scare the crap out of you when you are making high speed manuvers and the window start going down. Anyway, i was just wondering how much trouble it is to move them from the door to the console.
82-83 ZX's have power door locks... the driver's door locks & unlocks the passenger side.
Do you not have the plastic frame cover for the window switches? It wouldn't be hard to move them, just gotta rewire it...
OK. I found a section in the manual I downloaded about the power locks, but it doesn't tell me where the flippin fuse is located. I looked all thru the owners manual, and on the front side of the fuse cover...nothing about power locks. I am going to try to fix this this weekend, but I sure hate starting off blind. Any help will be greatly appreciated.
your passenger side actuator probably is broken. I had that happen. Open up the door panel from the inside and look.
From the factory, the pass door is the only door with a mechanism. My 280ZX has power locks both sides but the actuator in the driver's door is aftermarket and hooked up to an aftermarket alarm. (keyless entry!)
n_2_fairladyz
02-07-2006 02:58 PM
Heat Rave R
10-11-2004 09:18 PM
