Question????
Question????
My Cars RPM Gauge Sometimes Work And Sometimes Doesn't. Im Thinking Its The Connection Behind The cluster Because When I Wiggle The Cluster It Works. My Question Is How Do You Remove The Cluster, Is Removing The Dash Necessary???? Or Is There A better Way????
You Need To Take Off The Steering Wheel, And Undo The Bolts (Screws) Holding The Cluster In (I Believe There Are Four Screws), And It Should Come Out.
Once You Get The Steering Wheel Off You Should Be Able To Tell Exactly What Needs To Come Off.
domsgarage
10-11-2010 07:44 PM
