Rear End Clunking
Old 06-04-2008 | 04:37 PM
Z_lover's Avatar
Rear End Clunking
I have been hearing a clunking noise coming from my rearend of my '81 280ZXT. I originally thought it was my passenger side rear park brake dragging, but have since disconnect & replaced the worn pads. The noise persists. It starts off at about 15 mph and get faster as I speed up. Any suggestions?
Old 06-04-2008 | 04:55 PM
flightforlife07's Avatar
use search you should find the answer, but its most likely its going to be your diff mount going out
Old 06-04-2008 | 05:01 PM
280zx2by2's Avatar
Haterade by da gallon!
is it a definate clunk?, my muffler is falling apart(previous owner put a cheap one on) and i got pieces of metal and rock that rattle around in it but only past 1500 rpm
Old 06-04-2008 | 05:15 PM
Z_lover's Avatar
Do you mean the mean the isolator or the mount itself? What should I look for to identify the problem?
Old 06-04-2008 | 10:18 PM
Either the diff mount, half shafts, or driveline u-joints.
The diff mount is the rubber / metal bracket connecting the diff cover to the frame. Check it for cracks. Also while under the car rotate the half shafts & driveline by hand to check them.
Old 06-19-2008 | 10:07 AM
Z_lover's Avatar
Is this a common failure? I haven't had a chance to look at this yet but is definitely an annoyance. What is a worse case failure?
Old 06-19-2008 | 10:19 AM
Yep... SEARCH for "clunk"
zcrazy13
15
06-05-2019 01:22 PM
PredatorZ
03-18-2014 05:36 PM
Justin
09-07-2003 10:51 PM
Skully
03-20-2002 04:40 PM
Zpeed
01-02-2002 03:56 AM
