replacement engine
replacement engine
ok ok ok. so i'm sure the question has already been asked and honestly, i did a quick search and found nothing in the few minutes i looked. but here's the problem. i spun my main bearing and i know it's time for a rebuild or replacement. and right now on craigslist is a turbo'd engine running. if the compression tests out fine, would it be a good idea to put it in. same year but my car is n/a and his car has turbo. the engine sould just fall right in right? not to much work, just taking off the turbo and installing the downpipe. correct me if i am wrong. but what would you do??
https://www.zdriver.com/forums/showt...ght=turbo+swap
The list goes on. That first link should answer all your basic questions.
As far as getting the engine in the car, yes. Its a direct fit. BUT, and this is a bi but, its not just plug and play. If you dont transfer the wiring harness you have to splice in to the NA one which can be a pain, ECU, fuel pump just to name a few . . . .look more in to this 1st before buying unless someone wants to explain the whole thing. I did the NA to turbo swap. Trust me. its not plug and play
Lets say u buy the 280zx turbo u will need out of the donor car the " engine " tranny " drive shaft " rear diff. u will also need the engine bay wire harness the ecu wire harness " make sure to mark your fuel injector clips with tail nail polish 1-6 or else ! . U will need every sensor out of your donor car. Truthfully if u have about a week and 3 friends to help u can be able to get it done in week or less it took me and my wife 2 days to complete strip a 1981 280zxt from ground to bottom but then again i have tooken apart my cars and put them back togethor a few time if u havent ever tooken apart your 280zx then u better get some one who knows or start practicing if u lived close to me i would help if i had time to... on anther note there is a z guy on www.ebay.com that does rebuild l28e and l28et engine starting from 1800.00 to 2500.00 dollars look for his rebuilt engines.
DoTheDrew888
02-25-2005 02:36 PM
