revving problem
Old 08-06-2003 | 12:36 AM
icice9's Avatar
Super Siver & Black Stud
you might have a vacuume leak somewhere or your AFM is starting to go out.. i just recently had to change mine.. and i was having the same problem with mine before it totaly craped out on me and after changing it that problem went away..
Old 08-06-2003 | 07:43 PM
Skully's Avatar
boot
most likly your AFM boot check it i had exact same prob and it was pissin me off i changed my boot and now its good....
if its got cracks or holes in it that will affect it
Old 08-07-2003 | 12:33 PM
zpeedracer25's Avatar
Does this only happen the first time you start it in the morning or every time you start it even after driving it for a while?
If its only in the morning, you may have a cold start valve failure or faulty head temp sensor that is telling the computer that the car is warm and won't actuate the cold start valve. Could also be a bad fuel pressure regulator or a fuel pump that is allowing fuel pressure to bleed off when the car is off.
If its only while hot, you may still have a faulty head temp sensor, fuel vaporization due to malfuntioning fuel rail fan, or vaporization due to low fuel pressure. Or any number of things.
I'd start by hooking up fuel pressure guage and see if you're pressure is in spec and if it bleeds off while the car is parked. Always start with the basics.
thekid
06-23-2013 07:32 PM
newzowner2
12-19-2011 05:50 PM
skittle
08-26-2006 11:17 AM
Qosin
01-24-2006 08:14 AM
futureZowner
07-11-2003 01:14 PM
